Hmmm, first box design
I am using the box calc off this site, my subs say on the manual that for 1 sub for ported, it needs 1.20 Cu, with a 8.24 in length port with a diameter of 3 in. I want to keep the 1.2 Cu per sub and I have 2, Which I want to make a box, with 2 seperate ported boxes for each sub. I just am having a hard time using this calculator to figure shit out, I need to keep the width of the box at 33 in and need a 35 Hz port. I would prefer a non circle port, but when I take diameter off the calc and use width height instead it doesn't work. Help would be greatly appreciated.
Edit:My main questions on this are these. Box dimensions: Height is the height, width is width, so Depth is the "Length" in the L x W x H = Cu?
Port Dimensions: Width and Length are the W x L in the port, and height is how deep it is? This box design I came on with this if I think the calc is what I think everything means, is good, 2.4 Cu 35Hz, everything I need. Another question is, would it be fine to have 2 subs on top the box, with the port in the middle, and they share it?
Uploaded with ImageShack.us
Edited by RooTxBeeR
  • Soon To Be
  • '04 Ford Escape
  • US Alternator 280A Hairpin
  • D4800 Under the Hood
  • (6) XP3000's in Rear
  • Pioneer DEH-80PRS
  • DD AW6.5 (2) per door
  • *Tweeter Unkown*
  • DD SS4a & C3d
  • (2) SCV4000 @ .5Ohm
  • (2) 15" Sundown Zv5
bump, no one has even looked at this yet :( need help, have made a design based off this already.
  • Soon To Be
  • '04 Ford Escape
  • Pioneer DEH-80PRS
  • *Tweeter Unkown*
  • DD SS4a & C3d
Bump
  • Soon To Be
  • '04 Ford Escape
  • Pioneer DEH-80PRS
  • *Tweeter Unkown*
  • DD SS4a & C3d
you need more port area dude. you're at 14sqin and you need between 27 and 36. make the ports larger until the port area number reaches somewhere between the port area range spectrum.
X2 ^ Moar port!
2014 Chevy Silverado Crewcab
1994 Chevy Full Size blazer
Well if I change it, then my tuneing changes, and I need to keep the width of the box at 33in and a 35Hz tuning, also need it to stay at 2.4 cu.
  • Soon To Be
  • '04 Ford Escape
  • Pioneer DEH-80PRS
  • *Tweeter Unkown*
  • DD SS4a & C3d
I ran into the same problem, had 32or so sqin of port then changed it around and got 48sqin of port and went from 33hrtz to 40 hrtz but the lows are so fucking stupid and moves a lot more air
Since were all having a moment of truth.
I hate country too..
I'd only listen to it if I got some hotass bitch in my car and shes gonna suck my dick.
I was able to get the Hz at 35 and the port Sqin in the range, but the only problem is that I had to double the length of my port, which is double the actual length of my box.
  • Soon To Be
  • '04 Ford Escape
  • Pioneer DEH-80PRS
  • *Tweeter Unkown*
  • DD SS4a & C3d
many boxes have ports that bend (such as mine). its perfectly fine and it allows you to extend the port. google L Ported boxes for an idea
edit: and you have to put in a number for "# of common port walls". put 1 if the port touches 1 side of the box, 2 if it touches 2 sides, 3 if it touches 3 sides.
Edited by Kranny
you will just have to L your port to make up the difference
  • Who's Online   0 Members, 0 Anonymous, 1181 Guests (See full list)
