fmedina Posted April 5, 2011 Report Share Posted April 5, 2011 What's a good way to fit say a 18 in my trunk. Would it have to be like woofer up and port back? I want to be able to fit a larger sub in my trunk. The hight of my trunk is bout18-19" my 12 fits perfect facing back. Quote Link to comment Share on other sites More sharing options...
canderton01 Posted April 5, 2011 Report Share Posted April 5, 2011 (edited) fitting a good box for an 18 in a trunk is pretty tricky to do unless you drive a cadillac or something with a huge ass trunk. My Camry has a decent sized trunk and my 3.8 cu ft box for my 15'' is about as big as I could comfortably fit. Edited April 5, 2011 by canderton01 Quote 2002 Camry XLE 35% tints all around 17'' Enkei FD-05 rims Fi Q15 in 3.8cu ft box tuned to 32Hz Pioneer DEH-P7200HD AudioQue AQ1200d 4 Gauge Tsunami wiring/RCA's mids/highs - OEM JBL system AudioTechnix Deadner Big 3 upgrade My YouTube Link to comment Share on other sites More sharing options...
fmedina Posted April 5, 2011 Author Report Share Posted April 5, 2011 How do you have you sub positioned? Quote Link to comment Share on other sites More sharing options...
chapo123 Posted April 5, 2011 Report Share Posted April 5, 2011 depends if your seats fold down? what kinda car? if your seats fold down try to fire the sub and port both foward. sub up port back gives you a shit ton of rattle.. dont get the 18 if you cant get atleast 5 cubes.. what kinda sub and amp you tryin to get? Quote Steve I don't know why but everytime I see your new paint I want a Dr. Pepper...... is this normal? heres an analogy for you. running a high power stereo without a fuse is like having unprotected sex with that hot chick at the bar with the sketchy sexual history. Sure you may be fine and nothing happens but that one time something does happen you're fucked. i dont want woofer broke like bass sound clip clip and voice coil overheat 2 sa12s, saz1500 build log http://www.stevemeadedesigns.com/board/topic/91183-chapo123s-sundown-build-log/page__gopid__1250604entry1250604 Link to comment Share on other sites More sharing options...
The_Big_Tank Posted April 5, 2011 Report Share Posted April 5, 2011 If you glass the spare tirewell and build off of that you can have an 18 but thats th only way Quote 2x Mtx JH551204(soon to be 4) 2x Hifonics hfi12d4s 1xMTX Terminator 250.1 custom built box tuned to 35 hz Dual xdvd710 head unit (soon to be a double din) 1999 Pontiac Montana (minivan pimpin) Link to comment Share on other sites More sharing options...
fmedina Posted April 5, 2011 Author Report Share Posted April 5, 2011 Dam so then a 15 would me more realistic in a trunk? I have an aq1200 right now with a sa12 I was just wondering how I could get a bigger woofer to fit in my trunk cuz 12s seem to fit perfect. I have a 98 olds intrigue. Quote Link to comment Share on other sites More sharing options...
fmedina Posted April 6, 2011 Author Report Share Posted April 6, 2011 and yes my seats do fold down but sometimes when i give rides i have to put em up so i dont want to seal it at my trunk. Quote Link to comment Share on other sites More sharing options...
uhoh_45 Posted April 6, 2011 Report Share Posted April 6, 2011 check out my build here 18 in trunk of lumina Quote R.I.P! (Nov-29-2009) 92 explorer - 4 Atomic Apxx 15s duel .7s - 4rth order bandpass wall -4 powerbass XA-3000D's - 16 8volt batts wired to 16 volts - (9+/9-) runs 0gauge - 152.3 Db @ 29hz BUILD LOG current build 97 chevy lumina4 - 1 Atomic Apx 18 - 6 cube slot port trunk sealed off - 1 powerbass XA-3000D - 2 optima G31s in spare tire18 1 run 1/0 lumina build log Link to comment Share on other sites More sharing options...
fmedina Posted April 6, 2011 Author Report Share Posted April 6, 2011 check out my build here 18 in trunk of lumina oh ya i seen this before. did some good work man. but thats doing too much for me since i dont have all the tools and garage. and money of course ha. i was thinking more of just tryin to fit a box for a 15 or 18 if possible. Quote Link to comment Share on other sites More sharing options...
uhoh_45 Posted April 6, 2011 Report Share Posted April 6, 2011 you can do a 15 sealed off no problem if you have 18" tall also make sure when your measuring you measure from the trunk springs as they take away 1-3" of trunk Quote R.I.P! (Nov-29-2009) 92 explorer - 4 Atomic Apxx 15s duel .7s - 4rth order bandpass wall -4 powerbass XA-3000D's - 16 8volt batts wired to 16 volts - (9+/9-) runs 0gauge - 152.3 Db @ 29hz BUILD LOG current build 97 chevy lumina4 - 1 Atomic Apx 18 - 6 cube slot port trunk sealed off - 1 powerbass XA-3000D - 2 optima G31s in spare tire18 1 run 1/0 lumina build log Link to comment Share on other sites More sharing options...
