Depends on what woofer it is and what amp it is...
Current Systems:
2011 BMW 335i
Hertz HDP1
DC LVL3 12" Full Carbon Fiber
2002 Acura Tl
Kenwood DNX9980HD
2 DCLVL4 12" Subs with LVL5 Parts D.7 Coils
DC 3.5k
Hertz HSK-165 up front HCX-165 Rear
Hertz HDP4 Amp
DC Power Engineering 260 Amp Alt
Big 3 and amp powered with KNU 1/0
XS Power D2400 Up Front
i pulled out my dick in class many of times and had it shown. get over it bitch...stupid open legged hairy beavered bitch...
going over rms = smaller box, under rms = bigger box...
Low voltage doesn't blow amps. That's a myth.
A router that does the sub holes makes rounded edges also?
what sub is it
2002 ford focus hatch
pioneer DEH-P8400bh
infinity kappa 6.5 components front and rear
XS Power D1200
Shuriken BT-100
audioque 120.4
2 15 inch audioque HDC3 D2
2 audioque 2200d
big 3
mechman 220a alt with external regulator
479-418-3056
Depends if you know what your doing
It it's CLEAN power and you set the gain with a scope and the right box i think you will be ok..
2014 Chevy Silverado Crewcab
1994 Chevy Full Size blazer
The subwoofer is an MD Sound 12" and the amplifier is a BZA 3000D rated at 1200 watts RMS at 1.3 ohms.
My gains are set properly but i'm not so sure about the box as it is prefabricated.
Are they set with a o-scope?
I would build a new box that's to the specs of the sub if you plan on trying to run that much over RMS..
When I said they are set properly I meant to say that, yes, I did set them with an oscilloscope. Would you mind helping me through private message with the box fabrication?
Yea I can help
I'm no pro box designer/ builder but I can design a decent one
I'll need your max dimensions
Go for it if you set it right.
That amp isn't going to put out near 1300wrms so your sub should be fine as long as it can handle it's 800wrms.
Current Systems:
2011 BMW 335i
Hertz HDP1
2002 Acura Tl
Kenwood DNX9980HD
DC 3.5k
Hertz HDP4 Amp
  • Who's Online   0 Members, 1 Anonymous, 474 Guests (See full list)
