KevinniveK Posted April 7, 2011 Report Posted April 7, 2011 So i'm looking to do the big 3 in 1/0 gauge and also upgrade my power/grounds for my amp to 4 gauge. Would the chart below be an accurate way to determine what size fusing I would need for my big 3 1/0 gauge (positive battery to alternator fuse) and also my 4 gauge power to my amplifier. If this chart is correct then that means I should use a 325 amp fuse for my big 3 and a 125 amp fuse for my 4 ga power? Wire Gauge | Recommended Maximum Fuse Size 00 awg | 400 amps 0 awg | 325 amps 1 awg | 250 amps 2 awg | 200 amps 4 awg | 125 amps 6 awg | 80 amps 8 awg | 50 amps 10 awg | 30 amps 12 awg | 20 amps 14 awg | 15 amps 16 awg | 7.5 amps These are the recommended maximum fuse ratings for the corresponding wire size. Using a smaller fuse than what's recommended here will be perfectly safe.
Azagtoth502 Posted April 7, 2011 Report Posted April 7, 2011 What amp are you using? pa-pa-platypus sorry not everybody has a companies nuts so far down their throat they catch every drop ball sweat when it falls
KevinniveK Posted April 7, 2011 Author Report Posted April 7, 2011 BZA 3000D http://www.blitzaudio.com/manuals/BZA3000D.pdf It runs off 2x 40A fuses*
skittlesRgood Posted April 7, 2011 Report Posted April 7, 2011 you get that from BCAE1.com? that site is solid. you can trust it all. remember that chart is assuming OFC wire. if you have CCA then i would make the max rating of a full run of 1/0 250amps. also remember how long the wire is plays a big role in the amount of power a wire can handle. If I answered you in a well mannered, informative way, you asked a good question or had a good attitude. If I was an asshole, you asked a stupid question or you had a fucktard attitude... or I was in a bad mood. Team BassickHU: Pioneer AVIC Z110Front: Peerless SLS 6.5", Peerless HDS 4", Rainbow tweeter - running activeAmp: JL HD600/4 and DC 4 channel (bridged to midbass)Processor: JBL MS-8Subs: 2x 12" AA MayhemsAmp: DC 3kElectrical: DC power 270xp alt. 1/0 big 4. XSpower D3400 and six D680s. http://www.stevemeadedesigns.com/board/topic/121795-29-update-the-buick-is-getting-a-rebuild/ Top career scores: DBdrag 151.7 MECA SQ 82.25My SOTM build Yeah. im pretty sure they dont warranty retarded people.
KevinniveK Posted April 7, 2011 Author Report Posted April 7, 2011 Thanks a bunch to both of you & i'm using cca for my big 3 1/0 and ofc for my 4 gauge power so thatll be 250 amps and 125
