4th order blowthru opinions
So I'm still throwing around ideas for my 4th order blowthru enclosure. Just figured I would throw this picture up I did on Sketchup to see what you all think.
How would a design like this work(assuming the specs are correct).
2000 GMC Sonoma
AQ20 FTMFW!
4 DC XL 15's
Cadence ZRS-C9
Infiniti Kappa 3.5's and 6x8's
Bravox 6.5 components
would be better to do a V style
Edited by uhoh_45
R.I.P!
(Nov-29-2009)
92 explorer
current build
It all depends on the ratio ported to sealed but from what u know about 4ths and seeing as that I am currently building one my self it would be better to have the subs facing forward not up just my .02
Btw that was the first person. Ever banned by me while dropping a deuce. Feel privileged
Yeah I would rather them face forward as well, however the max height of my bed is 16 inches FTL. Sanitarium designed one for me with the subs angled to fit, but thats a lot more work to build.
Here is the one Sanitarium designed for me. Just trying to make the build a little easier!
Edited by Jbabycsx
2000 GMC Sonoma
AQ20 FTMFW!
4 DC XL 15's
Cadence ZRS-C9
ewwww
That is all
4th order, yes. subs facing up, no.
I looked for you in the chatroom to get your opinion but you werent there. I then turned to the masses lol
2000 GMC Sonoma
AQ20 FTMFW!
4 DC XL 15's
Cadence ZRS-C9
4th orders aren't easy they aren't for the novice if you don't want to put in the effort to make one that is worth it (sounds good) then I would just stick to a simple ported design the one sani did for you would be sick
Thats why I asked for opinions! I'm not willing to sacrifice quality for ease of construction. I just didnt know how the two would compare. Now I know and will stick with Sani's design. :drinks: Thanks for the input.
2000 GMC Sonoma
AQ20 FTMFW!
4 DC XL 15's
Cadence ZRS-C9
No problem man just remember 99% of the time if you put your heat and soul into it you will be rewarded with the results if you just throw together some wood and speakers that's how it's going to sound you get what you put in sometimes 10fold
lol. those angles aren't hard. draw it out on a board, work your angle out from there.
I actually did that with my last box. drew it out. then held the saw up to it and angled the blade to match the angle i drew.. . i know i cheat.
  • Who's Online   0 Members, 0 Anonymous, 2095 Guests (See full list)
