3kout Posted April 10, 2011 Report Posted April 10, 2011 I'm looking at upgrading my stock wiring in my car, the thing is I know how to do it, and what wires there SHOULD be, I've found the positive to the alternator, and the negative ground to the chasis, but I can't find any wire for the engine block to the chasis, and there's only one wire from the negative on the battery so the engine block isn't grounded there either. I've also noticed there's a bolt with a ring terminal on my chasis, but no wire, could it of been removed delibrately or accidently? or would my car not work without the engine block ground?, I've been searching for hours and can't find any other ground wires anywhere!
JEMT8 Posted April 10, 2011 Report Posted April 10, 2011 Make your own formerly known as Jaylor Swift
Azagtoth502 Posted April 10, 2011 Report Posted April 10, 2011 What car is this? pa-pa-platypus sorry not everybody has a companies nuts so far down their throat they catch every drop ball sweat when it falls
3kout Posted April 10, 2011 Author Report Posted April 10, 2011 It's a renualt clio, 2000 model I believe. And I was thinking of making my own, would grounding to anywhere on the engine block work? some bolts look rather important and I don't want my engine dropping to the floor when I take it out
Rogers Posted April 10, 2011 Report Posted April 10, 2011 Nope doesn't really matter. As long as you have good bare metal. http://www.stevemeadedesigns.com/board/topic/79921-rogers-700-dream-car-update-page-17-a-wall/?p=2335774 93 Saturn SC2My system4 SA-15's Walled 2 Cerwin-Vega S2000's 3 Kinetik Hc2000's Dual 200amp alts. you guys done with the peepee touching contest or do I need to end it?
