i think a normal pvc pipe would work. i have seen it before, it dosnt look to pritty but it gets the job done. and you could always curve the pipe in the box. by an 4" right angle and make the pip turn any way you need
ima adhesive some carpet on to the the pipe when i carpet my box maybe some hot glue lol
but i wont need to does i matter if the pipe some out of the side where my sub is as u see the box in pic the sub is between my seats and airspace part of the box is behind my driver seat so it would be ported out the passenger side and by the sub
can anyone confirm that this is 33hz
15 height x 30 width x 10 depth 1.67cu.ft
with a 30in long and 4in in pvc
What is the thickness of your mdf/ply wood
For that its going to be 1 inch and 12volt.com says that thoes specs its going to be 1.68519 cubic feet
if you want 33hz at 4 Diameter pvc then it only needs to be
15.52772 inchs long
Check it out http://www.the12volt.com/caraudio/boxcalcs.asp
Edited by DeathByBass
  • Who's Online   0 Members, 0 Anonymous, 697 Guests (See full list)
