matt14 Posted April 11, 2011 Report Posted April 11, 2011 When I did my first system, I diddnt relize that the power wire that I bought from knu was CCA. Never had a issue with anything before with it, but know im upgrdaing my system to a Crescendo 3kwp on a XL 18 and a Crescnedo 1000c4. The 3k will be run down to .5ohm. I already have a XS 3400 under the hood and will be adding another for a second, and already have the DC alt ( 250 ). So what i was thinking about doing, was running the other 3400 under the hood like this..... http://www.tahoeyukonforum.com/forum/showthread.php?t=562 without the isolater. So that i dont waste the left over 1/0 cca from Knukonceptz, will run dual power and dual grounds to this battery. Then from that batttery will run the power wire for the amps ( will go with stinger comp wire from darevex ). Fuses will be on each positive cable( 250 each ) from the main battery to the second battery (within 12" of the first), 300amp fuse to the 3k and 80 amp to the 4 channel. Also will throw a 250amp fuse on the alt wire ( alreay upgraded to 1/0 but will fuse with alt install). What do you all think about this? Gonna order up the stinger wire tommorrow along with all the fuse holders and a volt meter. 2006 GMC YukonPioneer HU SHCA ran throughout Crescendo BC3500 One 18 AA Mayhem in a 4th order ZED Levithian 6 channel Rainbow Dual 6.5 comps ran Activehttp://www.stevemeadedesigns.com/board/topic/155628-matt14s-yukon-mayhem-in-a-4th-ordernew-amps-and-bats/page-3
jmilch Posted April 11, 2011 Report Posted April 11, 2011 That actually sounds perfect. You shouldn't run into any issues. Pioneer AVH-P4300DVD | Hertz 6.5 | Alpine Type R 6x9 | Custom 200A Alt | Knu Flek 1/0 Big 3 and all wiring | Eclipse EA3422 | AudioQue 2200d | DC XL 12 | Red Oak Box ~2.8 cubes @ 30 hz |
