RickyFriery97 Posted September 13, 2011 Author Report Posted September 13, 2011 love the build man, nice looking tahoe as well! thanks dude 2014 Chevy Silverado Crewcab 1994 Chevy Full Size blazer
RickyFriery97 Posted September 13, 2011 Author Report Posted September 13, 2011 So you have all your negative return power for the batts going through that clamp now? Good deal. i have the main 1/0 engin block ground, and the little 8 gauge? ground i think for the headlights going through it, as for the second D3400 its grounded to the frame and the firewall. but i was thinking if i run 1/0 in parallel between the batts the current clamp will work for both of them. Hmm you should just ground the second D3400 to the first battery so all the battery return power goes through the clamp. so take the frame and firewall ground out completly? what about the charge line to the second D3400? 2014 Chevy Silverado Crewcab 1994 Chevy Full Size blazer
RickyFriery97 Posted September 14, 2011 Author Report Posted September 14, 2011 So you have all your negative return power for the batts going through that clamp now? Good deal. i have the main 1/0 engin block ground, and the little 8 gauge? ground i think for the headlights going through it, as for the second D3400 its grounded to the frame and the firewall. but i was thinking if i run 1/0 in parallel between the batts the current clamp will work for both of them. Hmm you should just ground the second D3400 to the first battery so all the battery return power goes through the clamp. so take the frame and firewall ground out completly? what about the charge line to the second D3400? Yup cut any grounds on the second battery, just ground it directly to the first battery's negative post. If you're worried about not having enough bandwidth to ground, replace the 1/0 ground on the first battery with 4/0 (which should fit through the clamp). alright ill do that, just one run of 1/0 for negative to negative? what about positive? 2014 Chevy Silverado Crewcab 1994 Chevy Full Size blazer
RickyFriery97 Posted September 14, 2011 Author Report Posted September 14, 2011 pulled the plastic pieces that were glued to the carpet out so my box can sit flat without a false floor took my max dimensions for shits and giggles, i have about 18.5 cubes to play with, under the window line and with 9" of clearance from the hatch 2014 Chevy Silverado Crewcab 1994 Chevy Full Size blazer
RickyFriery97 Posted September 14, 2011 Author Report Posted September 14, 2011 So you have all your negative return power for the batts going through that clamp now? Good deal. i have the main 1/0 engin block ground, and the little 8 gauge? ground i think for the headlights going through it, as for the second D3400 its grounded to the frame and the firewall. but i was thinking if i run 1/0 in parallel between the batts the current clamp will work for both of them. Hmm you should just ground the second D3400 to the first battery so all the battery return power goes through the clamp. so take the frame and firewall ground out completly? what about the charge line to the second D3400? Yup cut any grounds on the second battery, just ground it directly to the first battery's negative post. If you're worried about not having enough bandwidth to ground, replace the 1/0 ground on the first battery with 4/0 (which should fit through the clamp). alright ill do that, just one run of 1/0 for negative to negative? what about positive? Positive don't matter as far as the clamp is concerned, just 1/0 between the two battery positive posts, then hang alt/starter/whatever wires off the most convenient posts. yea, but right now i have 2 1/0 charge lines of the alt plus the stock line, 1 1/0 goin to each batt. you think i should just run 1/0 to the batts in parallel and get rid of the second 1/0 charge line? as seen here 2014 Chevy Silverado Crewcab 1994 Chevy Full Size blazer
RickyFriery97 Posted September 14, 2011 Author Report Posted September 14, 2011 So you have all your negative return power for the batts going through that clamp now? Good deal. i have the main 1/0 engin block ground, and the little 8 gauge? ground i think for the headlights going through it, as for the second D3400 its grounded to the frame and the firewall. but i was thinking if i run 1/0 in parallel between the batts the current clamp will work for both of them. Hmm you should just ground the second D3400 to the first battery so all the battery return power goes through the clamp. so take the frame and firewall ground out completly? what about the charge line to the second D3400? Yup cut any grounds on the second battery, just ground it directly to the first battery's negative post. If you're worried about not having enough bandwidth to ground, replace the 1/0 ground on the first battery with 4/0 (which should fit through the clamp). alright ill do that, just one run of 1/0 for negative to negative? what about positive? Positive don't matter as far as the clamp is concerned, just 1/0 between the two battery positive posts, then hang alt/starter/whatever wires off the most convenient posts. yea, but right now i have 2 1/0 charge lines of the alt plus the stock line, 1 1/0 goin to each batt. you think i should just run 1/0 to the batts in parallel and get rid of the second 1/0 charge line? as seen here <edit> Actually running these batts in parallel may not be a good idea depending on how the alts are controlled... the OEM alt will be PCM controlled so it will not always be 14v, but I guess your second alt is relayed-controlled to a constant 14v, so if you let them "see" each other's voltage, this may cause the first alt to not work at all or go haywire? Might be better then just to take the approach of completely separating alt 2/battery 2/audio system from alt 1/battery 1/OEM stuff. But wait, do you just have 1 alt now or 2? I thought it was 2, but I see just 1 alt. In THAT case, run the batts in parallel. i alt for now! once i get duals, the second alt will be a 270+ amp alt and completly seperate from the oem stuff and will power just the amps/batterys. for now im gunna go ahead and run them in parallel 2014 Chevy Silverado Crewcab 1994 Chevy Full Size blazer
RickyFriery97 Posted September 15, 2011 Author Report Posted September 15, 2011 Rockford Fosgate T2500BDCP will be here today 2014 Chevy Silverado Crewcab 1994 Chevy Full Size blazer
CrashHole Posted September 15, 2011 Report Posted September 15, 2011 Looking good Rick!! Me and Clint need to roll up to your pad in my Tahoe so you can perform some magic on it lol No matter how hot she is, someone, somewhere, is sick of her shit. 99 Tahoe: 2-10" MA Audio 4-6.5" Kenwood door speakers Total Amp Sony HU
RickyFriery97 Posted September 15, 2011 Author Report Posted September 15, 2011 Amp is here Birthsheet wasant as high as i hoped for, but it will get the job done 2014 Chevy Silverado Crewcab 1994 Chevy Full Size blazer
dwright27 Posted September 15, 2011 Report Posted September 15, 2011 Sweet. 2006 F-150 4 DC XL M2 18's Walled Daily Driver XS Power 4 DC 3.5kw Team DC Team S.P.L. Lot of Audio Technix and 1/0 DC Audio Dealer American Bass Dealer XS Power Dealer Audio Technix Dealer
