Jcoleman134 Posted September 27, 2007 Report Share Posted September 27, 2007 Well i hooked my other sub up today and the fuses blew on the amp after a little bit of play. I know it has to be the wiring but im not too sure. Anyone know what the problem is? Link to comment Share on other sites More sharing options...
gotFI? Posted September 30, 2007 Report Share Posted September 30, 2007 Well i hooked my other sub up today and the fuses blew on the amp after a little bit of play. I know it has to be the wiring but im not too sure. Anyone know what the problem is? the amp fuse or the power line fuse? whats the fuse size on the amp? wiring is the problem. but where is the question. start trouble shooting. if you have a 200 amp fuse line and a 100 amp fuse in the amp. the lesser amp fuse will blow first. meaning your amp fuse should be geater then the powerline fuse. so that in mind, the powerline fuse will give out before hitting your amp fuse. keyword....UPGRADE! Link to comment Share on other sites More sharing options...
EricM9104 Posted September 30, 2007 Report Share Posted September 30, 2007 What ohm load do you have the subs wired to the amp? What amp do you have? Does it support the ohm load the subs are wired to? 2015 Honda Civic LX 4dr | 24k miles Stock H/U and mids/highs Power Acoustik GW3-12" D2 Sub HiFonics BXX1200.1D @ 1ohm Random 2.5^3' dual ported box NVX LOC Stinger wiring throughout 1977 Chevy SWB Cammed 350 Dual exhaust Cheap Wish stereo Link to comment Share on other sites More sharing options...
