Kian Posted April 17, 2011 Report Posted April 17, 2011 I have a question, Im about to order my recone for a Fi BTL Dual 2 FL. Right now i own a Saz-3000d and plan on purchasing 1 more very soon, i have plenty of electrical so no worry's there. TO have this configuration what Dual ohm woofer would i need (I think its dual 2 ohm)? trapped @ 0.7ohms, with each amp at .35 Woofer +,+= .7 -,-= .7 amp ????? how would i wire the amp's? Thank you kian --------------------------------------------------------------- Club 150 (15x.x) Youtube Future Build: 1x 15" T3 TSNS 2x Sundown Audio SAZ3000d Parellel strapped
hdorre Posted April 17, 2011 Report Posted April 17, 2011 The master amplifier gets the input from the head-unit and a mono RCA from "BR Out" connected. The slave amplifier ONLY gets "BR In" connected from the master. ALL controls are handled on the master, setting anything on the slave is not necessary. This picture should be pretty self explanatory. * The slave takes the "-" connection(s) * The master takes the "+" connection(s) * The "-" terminals of the amps are hooked together. You don't need to use both sets of "+" on the amps. They are there for flexibility. While you should always connect both "-" terminals on the amps together using large wire as general procedure it is not absolutely necessary to use both sets of "+" terminals. They are connected together internally in parallel. On 5/8/2011 at 7:38 PM, Kranny said: On 5/8/2011 at 7:35 PM, 'Maxim' said: It hurts me inside when I read stuff like this and remember you're 15 LMFAO so true Mitsubishi 3000GT (Old Build) Headunit: Pioneer 80PRS Frontstage: (2) McLaren Audio MLT-2 Tweeters & (4) PRV Audio MR Series Neo 6.5" Mids Substage: 4 15" Hybrid Subs - Tantric Motors & Sundown Softies Amps: Banda 2.4D Amp (Tweets), American Bass VFL 350.4 (Mids), and (2) Ampere 3800s Electrical :Singer 260A Alt & JY Power Lithium 2005 Chevy Colorado Ext Cab Headunit: Pioneer 80PRS Frontstage: 4 PRV 700Ti Tweets & 6 10" Delta Mids on 3000wrms Substage: 6 Fi BTL 18s in a 4th Order Walkthrough on 3 Wolfram 4500s Electrical: Singer "390" and JY Power My Official Feedback Thread
Kian Posted April 17, 2011 Author Report Posted April 17, 2011 SO if im only running one woofer i just leave one of the terminals on each amp empty + to + and - to - and master get + and salve get's the -. thank you. --------------------------------------------------------------- Club 150 (15x.x) Youtube Future Build: 1x 15" T3 TSNS 2x Sundown Audio SAZ3000d Parellel strapped
