I'm trying to mess around with WinISD on a sub that isnt in the list.. well i found everything i needed except for the Le abbreviation. Answer should be in mH. Ive googled everything i can think of and still not coming up with anything. Also not sure about what the Dia stands for
Here is what i got. This is for a 15" Sxx RE audio
qts .38
vas 126.3 l
fs 27.8
re 1.9
Le
xmas 22mm
z 2
qms 4.7
qes .38
SPL: 90.4
pe 1000
bl 21
dia 14 (is this suspose to be 14? Diameter of what? )
sd 810 cm^2
qts .38
vas 126.3 l
fs 27.8
re 1.9
Le
xmas 22mm
z 2
qms 4.7
qes .38
SPL: 90.4
pe 1000
bl 21
sd 810 cm^2
to be honest, winISD isnt the most accurate out there. i NEVER base my box designs on the subwoofer. I judge the box's airspace on the size and RMS output of the subwoofer.
this is what i do-
my last build was for a alpine type R 12, and if you havent noticed, it's not in the "drivers" list. Basically, i did some research, and i decided to build the box based on the JL w6 (because it is most similar in size and RMS output). in the end, the box ended up making the sub sound BEAUTIFUL tuned to 37 hz.
my suggestion is to find the most similar subwoofer (to your own sub) in the list, and plan the box to that. hope i helped.
1999 Monte Carlo
Sony CDX-GT34w
2 Alpine Type R 12"s in 4 cubes tuned to 35hz
American Bass VFL 80.1 amp @ 1 ohm (probably doing between 1000 and 1300rms)
Stock alt, Stock batt, Big 3 Upgrade
Boston s55- 5 1/4s (doors)
Boston s95- 6x9s (rear deck)
