All the Dimensions Are On The Sketch Except For The Height Which Is 17".
Check Top Of Paper For Cubes, And Tuning.
http://s303.photobucket.com/albums/nn150/Jmoney2544/?action=view&current=ham020.jpg
Car: 2002 Buick Regal
Wiring: Knu Kolossus 1/0 + JL 4 Gauge
Big 3: Stinger HPM 1/0
Alternator: Stock 135 Amp
Batterys: Optima RedTop (Hood) XS D3100 (Trunk)
HeadUnit: Pioneer DEH-4200UB
Subs: (2) AQ HDC3 12's
Sub Amp: AQ 2200D
Sub Box: 4.6 Cubes @ 36hz
Mids & Highs: (Front) Rockford Fosgate Power T1693 3-Way 6x9's
Mids & Highs: (Rear ) Rockford Fosgate Power T152S 2-Way Component 5.25"
Speaker Amp: AQ4x90
Sound Dampener : 75 Ft Fatmat
lmao!!! same design different spec.. wtf dude, get the port on the same side of the subs...
the port wall doesnt extend to the one side 7". not the same
Edited by Jmoney2544
Sub Amp: AQ 2200D
Speaker Amp: AQ4x90
try again
need at least a 6" port width for these subs. cant do it in the front. i might try triangle ports
Sub Amp: AQ 2200D
Speaker Amp: AQ4x90
thats the design i got.. 6 in port in the front with the subs.
total sub diameter = 15.75"
15.75" x 2 = 31.5
31.5 - 36 = 4.5"
cant do it
Sub Amp: AQ 2200D
Speaker Amp: AQ4x90
actually more like 5 .. oops.. but it should do the trick.. if you're gonna require a 6 inch port.. then go with smaller subs bro.. otherwise good luck
you think 5" will be good for no port noise with a 6 cube box
Sub Amp: AQ 2200D
Speaker Amp: AQ4x90
