1. Product:
Rd Audio 3250V2 amp
2. Specs:
* Digital class-D linkable mono block amplifier
* MOSFET PWM power supply
* Daisy-chain through output RCA
* Double sided through hole epoxy PCB
* Stable into 1 ohm and 2 ohm parallel amplifier connection availability
* 24dB/oct variable crossover
* Variable subsonic filter
* Variable bass boost
* Variable low pass filter
* Variable phase shift
* Efficiency : 86% @ 4 ohm, at 100Hz
* Multi-way protection circuitry (Thermal/over current/speaker short/speaker dc protection)
* RCA line input
* Tested voltage & THD : 14.4V & less than 1% THD
* Operating voltage : DC 10V~18V power input- 2008 models
RMS power, 2 ohm linkable/dual mono 5600w x 1ch RMS power, 0.875 ohm mono 3750w x1ch RMS power, 1 ohm mono 3000w x1ch RMS power, 2 ohm mono 1500w x1ch RMS power, 4 ohm mono 750w x1ch Signal to Noise Ratio >100dB Low pass frequency crossover 35Hz~300Hz Subsonic filter 10Hz~60Hz Bass boost @ 45Hz 0~18dB Phase shift control 0~180 degree Frequency response 10Hz~350Hz (+/- 1dB) T.H.D @ 4 ohm <0.1% Efficiency @ 4 ohm 86% Fuse rating 300A(external type fuse – not included) Input Sensitivity 200mV to 6V (+/- 5%) Dimensions 222(W) x 52(H) x 590(L)mm
3. Description/Condition:
Blown. Turns on for few seconds, then turns off. Protect light flashes when it turns off but doesn't stay on. Could get it fixed, I do not have any quotes from anyone. I do have the bass knob, not sure if it works I never used it, you will need to get the 5-pin phone cord for it. I cannot see any visible burn marks on the board.
4. Price:
100 + shipping
5. Pictures:
Team DC Audio : Team Shok : Team NWSPL Co-Founder
Head: Pioneer AVH-P5200DVD
Front Stage: Morel Tempo 6.5's/ CDT 6.5's
Subs: (4) 15'' DC XL's, 15 cubes @ 38hz
Sub Amps: (2) Shok 5k's
Speaker Amp: Shok 100.4
Wiring: Shok Industries 1/0
Electrical: White Mechman 270/Adjustable Voltage/3 Shuriken BT120's/3 XS XP3000's
FPiYT.jpg?9395
Can you get a quote to get it fixed? And if you fix it once is it good? Cause i know these amps have had problems...
1990 Nissan 300zx Twin Turbo - Summer Ride(No system yet, lookin to get it up to 450-500 horse first!)2006 Chevy Malibu - Daily DriverDC Level 5 15", 2 APSM-1500's, 3.88 cu. ft. tuned to 32hz1992 Honda Prelude - SOLD2 18" TC 3hp Woofers on a Crescendo BC3500.1d, 12.7 cu. ft. tuned to 35hz7r.png
I called RD he said they don't have the parts to fix it, he said he knows some people if you give him a call and ask he can refer you to them
FPiYT.jpg?9395
PM sent
Pioneer AVH-P4300DVD | Hertz 6.5 | Alpine Type R 6x9 | Custom 200A Alt | Knu Flek 1/0 Big 3 and all wiring | Eclipse EA3422 | AudioQue 2200d | DC XL 12 | Red Oak Box ~2.8 cubes @ 30 hz |
This topic is now closed to further replies.
