1991 Lincoln Town Car Signature Series
DC Power 270 Amp Alt
Big 3
Kicker/KnuKonceptz 0 Gauge Power wire
XS Power D6500
XS Power D3100
Pioneer Headunit
JBL Mids and Highs
Rockford Fosgate 400.4
3 Sundown Audio SA-10's wired @ .67 ohms
American Bass 150.1
OK, so you have 2 4 ohm single voice coil subs. With a 2 channel bridgeable amp, probably nom Impedance of 2 or 4 ohms. This is how you need to wire them to get 2 ohm load to your amp.
RF Wiring wizard
This x2
Big 3
XS Power D6500
XS Power D3100
Pioneer Headunit
JBL Mids and Highs
American Bass 150.1
Posted (edited)
Im not sure what the back of them look like but yeah they look just like them just 10's not 12's
It doesn't matter, they are still single Voice coild 4 ohm subs. Make sure they are wired the way the RF model shows you to wire them and you should be bumpin like a maniac. BTW that legacy amp is probably putting out closer to 500 maybe 700 RMS bridged at the most. You should be able to bump them pretty good, but don't just go cranking your gain away, you need to PROPERLY adjust the gain and settings on the amp to make sure you don't overheat them and blow them. Legacy amps aren't too great so I would upgrade to something better in the near future. Audioque AQ750 would probably do all right for you. Cheap too.
Put some real clean power to those subs<---when you can afford it.
Edited by bassinblazer
BassinBlazer
JL[RF][Kenwood][AQ]
I need a new amp! Sell me your amp!
Posted (edited)
Look it up on here, as there are SEVERAL threads with many knowledgeable people on how to set gains and settings on amps. With that amp though, it is very important, because it has the potential to push those subs to their RMS, but they are not very clean power, which will create a good bit of heat and if not set properly, it will burn up your subs.
You could also you tube it. I am a visual kind of person and learn better from watching, not reading.
BassinBlazer
JL[RF][Kenwood][AQ]
I would just put it back the way it was and use it for now till you out grow it and want more, so in the mean time just read on here as much as you can to learn more about this hobby.
01 Ford focus ZX3
Pioneer AVH-X491BHS
PPI PC 4800.2
Morel Maximo 6.5" x2
