bigaltexas Posted April 21, 2011 Report Posted April 21, 2011 was running a powerbass xa4000d off 2 batteries.. know i gotta step up the batteries, can anyone give a word of advice on what i should get? been looking at the xs power d3100 Power Cell 5000 Amps, but how many would i need do yall think? also going to be running the d2 smd at .5 ohms i believe? got both the positives coming together into 1 wire and both the negatives coming into 1 wire.. thats .5 isnt it? anywaysss, thanks yall..
bumonskateboard6 Posted April 21, 2011 Report Posted April 21, 2011 You can only run a D2 sub at 1 or 4 ohms. But yes you are running it at 1 ohm currently. If you want to run a 4500D I'd suggest upgrading your front battery to the largest XS power that will fit in the stock location, as well as 1 D3100 in the back, and 2 runs of 1/0 to wire them in parallel. Current Systems: 2011 BMW 335i Hertz HDP1 DC LVL3 12" Full Carbon Fiber 2002 Acura TlKenwood DNX9980HD2 DCLVL4 12" Subs with LVL5 Parts D.7 CoilsDC 3.5kHertz HSK-165 up front HCX-165 RearHertz HDP4 AmpDC Power Engineering 260 Amp AltBig 3 and amp powered with KNU 1/0XS Power D2400 Up Front i pulled out my dick in class many of times and had it shown. get over it bitch...stupid open legged hairy beavered bitch... going over rms = smaller box, under rms = bigger box... Low voltage doesn't blow amps. That's a myth. A router that does the sub holes makes rounded edges also?
