bassrace Posted April 22, 2011 Report Share Posted April 22, 2011 I have 2 hdc312s and they were sounding fine for the first couple of weeks. Well i havent changed a thing and i was riding down the road bumpin and i restarted the song i was playing and then my lows sounded totally differnt. What i mean by that is they wernt near as loud and sounded a little differnt. It is a big difference. I have checked everything and now im clueless plz anyone with suggestions plz help i am getting my soundstream bx-20z tomorrow by fedex and want to get to get this solved today. Thanks in advance Quote 145.9@40hz 145.3@34hz big 3 X2 group 34 Deka Group 31 All 0/1 awg jl meta wire Alpine CDA 7894 Orion HCCA D5000 2 AQ HDC312's Crunch gpv1100.2 (for 6.5"s only) AQ pro audio 6.5" - 3 sets AQ supertweeters - 2 sets 2000 Slamry Link to comment Share on other sites More sharing options...
Azagtoth502 Posted April 22, 2011 Report Share Posted April 22, 2011 Check all the wires, settings, everything.....hard to say without more details. Quote pa-pa-platypus sorry not everybody has a companies nuts so far down their throat they catch every drop ball sweat when it falls Link to comment Share on other sites More sharing options...
bassrace Posted April 22, 2011 Author Report Share Posted April 22, 2011 Well all setting are the same i messed around with my amp but set everything back were it was before. My hu is the same and just pulled my speakers out at the car wash cuz it was raining.lol but all things are the same its kinda wierd. Btw i do all my installs myself i know my equipment top to bottom and im just stuck Quote 145.9@40hz 145.3@34hz big 3 X2 group 34 Deka Group 31 All 0/1 awg jl meta wire Alpine CDA 7894 Orion HCCA D5000 2 AQ HDC312's Crunch gpv1100.2 (for 6.5"s only) AQ pro audio 6.5" - 3 sets AQ supertweeters - 2 sets 2000 Slamry Link to comment Share on other sites More sharing options...
bassrace Posted April 22, 2011 Author Report Share Posted April 22, 2011 Oh i should prob add that it seems like the subs are moving the same. Silly q but Could they just go out of phase randomly? Im not a noob.lol i just dont know everything Quote 145.9@40hz 145.3@34hz big 3 X2 group 34 Deka Group 31 All 0/1 awg jl meta wire Alpine CDA 7894 Orion HCCA D5000 2 AQ HDC312's Crunch gpv1100.2 (for 6.5"s only) AQ pro audio 6.5" - 3 sets AQ supertweeters - 2 sets 2000 Slamry Link to comment Share on other sites More sharing options...
Neo_frog Posted April 22, 2011 Report Share Posted April 22, 2011 No way to be out of phase randomly. And yeah, they are moving, but you can't see if one is just acting as a passive radiator (i.e. blown) with your eyes alone. I suggest pop testing from the amp to make sure they are both getting signal. Then test AC voltage off the amp on both terminals. Please list your current amp also. Quote Need an install? Hit me up.[email protected]Got car audio questions? Check here first!Everything you need to know. =]http://www.stevemeadedesigns.com/board/topic/83029-everything-you-need-to-know/ Link to comment Share on other sites More sharing options...
bassrace Posted April 22, 2011 Author Report Share Posted April 22, 2011 Ok its an orion d5000 its wired at 1ohm and there dual1ohm subs ill double check again to make sure a wire or somthing isnt loose but it would have be inside the box i couldve overlooked it maybe Quote 145.9@40hz 145.3@34hz big 3 X2 group 34 Deka Group 31 All 0/1 awg jl meta wire Alpine CDA 7894 Orion HCCA D5000 2 AQ HDC312's Crunch gpv1100.2 (for 6.5"s only) AQ pro audio 6.5" - 3 sets AQ supertweeters - 2 sets 2000 Slamry Link to comment Share on other sites More sharing options...
Neo_frog Posted April 22, 2011 Report Share Posted April 22, 2011 That's why you pop test. No need to remove anything. Quote Need an install? Hit me up.[email protected]Got car audio questions? Check here first!Everything you need to know. =]http://www.stevemeadedesigns.com/board/topic/83029-everything-you-need-to-know/ Link to comment Share on other sites More sharing options...
bassrace Posted April 22, 2011 Author Report Share Posted April 22, 2011 Whats a pop test sry to sound slow Quote 145.9@40hz 145.3@34hz big 3 X2 group 34 Deka Group 31 All 0/1 awg jl meta wire Alpine CDA 7894 Orion HCCA D5000 2 AQ HDC312's Crunch gpv1100.2 (for 6.5"s only) AQ pro audio 6.5" - 3 sets AQ supertweeters - 2 sets 2000 Slamry Link to comment Share on other sites More sharing options...
bassrace Posted April 23, 2011 Author Report Share Posted April 23, 2011 Problem solved speaker wire was loose under electric tape on the terminal cup thanks for the help ppl Quote 145.9@40hz 145.3@34hz big 3 X2 group 34 Deka Group 31 All 0/1 awg jl meta wire Alpine CDA 7894 Orion HCCA D5000 2 AQ HDC312's Crunch gpv1100.2 (for 6.5"s only) AQ pro audio 6.5" - 3 sets AQ supertweeters - 2 sets 2000 Slamry Link to comment Share on other sites More sharing options...
