XS Power
Which xs battery would be the right size as a direct replacement for under the hood of a 04 ford explorer?
2004 Explorer Limited
24" Lexani "pyros" wrapped in 255/30/24 pirelli's
270 Amp MechMan Alt.
(2)Stinger SPP-2150's
(2)Sundown NightShade 15's
IA 40.1
I was told a D6500 will fit perfectly so thats what I ordered for my 05. idk what years his is but I was just looking at loudmofo's explorer build and he put in a D3100 sideways in the batt slot.
I don't fuck around. I go from zero to I hope you die in less than 2 posts
build log http://www.stevemeadedesigns.com/board/topic/104524-new-subs-coming-sundown-3500d-arc-audio-cable-lacing-crescendo/
As said above the D6500 is the direct replacement battery, but others have gotten larger batteries to fit with little to no modification. If you are not going to hook up your cables with ring terminals, then you will also need a set of 580 or 586 brass posts.
