hibatch Posted April 25, 2011 Report Posted April 25, 2011 My friend got rid of his system so I took his 4 gauge wires and cap, the problem is the cap doesn't turn off when I shut the car off, it still shows the led numbers, is that normal? Hibatch 6.5 infinity components 6x9 infinity coax infinity 611a amp 2 13" JL w3's ported Big 3
ch0sen Posted April 25, 2011 Report Posted April 25, 2011 some led caps have a remote line for the voltage meter but most don't and dont' cut off aslong as power is running through the cap My current 95 Jetta Build w/ pioneer h/u 2 RD Sonance 10's with flatwind coils 2 Audiopipe apsm 1500.1s 1 Hifonics Brutus Elite 60x4 1 XS d925 1 Stinger spv35 1 1000 amp lead acid 50 ft of 0/1 ofc from Audiotechnix all powerbass components, and coaxils, 4 sets buildlog = http://www.stevemead...2-rd-10s-build/ My build for my wife. http://www.stevemead...01-f-150-build/
hibatch Posted April 25, 2011 Author Report Posted April 25, 2011 Ok, this one doesn't have a remote line, so I shouldn't worry about this draining my batt? Hibatch 6.5 infinity components 6x9 infinity coax infinity 611a amp 2 13" JL w3's ported Big 3
18abVFL Posted April 25, 2011 Report Posted April 25, 2011 Ok, this one doesn't have a remote line, so I shouldn't worry about this draining my batt? just gte rid of the cap, they're worthless. youll see better results doing a big 3 1999 Monte Carlo Sony CDX-GT34w 2 Alpine Type R 12"s in 4 cubes tuned to 35hz American Bass VFL 80.1 amp @ 1 ohm (probably doing between 1000 and 1300rms) Stock alt, Stock batt, Big 3 Upgrade Boston s55- 5 1/4s (doors) Boston s95- 6x9s (rear deck)
mrd6 Posted April 25, 2011 Report Posted April 25, 2011 Depending how you have it wired caps aren't "useless" but they are not really going to help with voltage drop 99% of the time so... But if you drive your car more often than never you do not have to worry about the cap draining your battery. Once caps charge, they form a short so no current is flowing through them anyways. The amount of current draw for those LED lights is also going to be negligible for you unless you leave the car sitting cold for months at a time. Edit: true that on the big three tho My Build Log: http://www.stevemead...-sundown-power/ Team NorthWestSPL
