where to where do i have to measure? im building this enclosure for my 15 and im trying to tripple baffle it AND i dont want to build a port wall, just leave the three baffles as the "wall". so where exactly is my port length? thanks
refs: chode69, superduper
okay so that would be .75 x 3 = 2.25" .... now if my port is 9 inches wide, do i divide that by 2 and add that to the port length of 2.25 as end factor?
Hope you like not being able to play below 70Hz.
thats where you're wrong. it peaks at 53hz and plays music better than most will think.
So it peaks below the port's tuning frequency? Good luck with that.
yes it peaks below port frequency.
how many cubes is the box? and what is the port width and height?
i made the box with two baffles insteead, which has an internal space of 6.1 cubes before sub displacement, which is about .5 cubes.
the port area was 17.5 x 8.5 and 1.5 deep from the two baffles. from winISD, my tuning "should" be around 77hz, peaking about 5hz higher than tuning frequency = low 80s, but i peaked at 53.
  • Who's Online   0 Members, 0 Anonymous, 1800 Guests (See full list)
