DC Sound Lab
Box help for a hatchback for Lvl 2 12s
If you're going to use a slot port, you're looking at around 24" of height, minimum.
Edited by RAM_Designs
Ryan Miskin - owner of RAM Designs
I have my PM's turned off, please email at <script data-cfhash='f9e31' type="text/javascript"> /* */</script>
2200+ designs since March 2011...
Or you could save some space by using a single 6" aeroport...but you only have 28" of width to work with, so that won't work.
  • 3 weeks later...
So if I go 3 ft total, do I need to make the box a little bigger to compensate for the the port or is it 3 ft and leave it at that. Also can I still do a down firing box? And will going ported sound better in a hatch like my cube than a sealed box.
Edited by onyx1silverado
Pioneer AVH-P4200DVD
Rockford Fosgate T5001 bd-cp
2 DC level 2 12's
Focal Access Components in the front
Focal Access Coax in the rear doors
Rockford Fosgate Punch Boosted Rail 4 channel rms 4x75
XS Power D3400 under the hood
Knuconceptz Ultra Fleks Power & Ground
thats a pretty tiny car, id fire subs & port up.
read up & design box here >>> http://www.the12volt.com/caraudio/boxcalcs.asp
3 cubes NET, which is after port, sub, & bracing displacement.
id do a slot port with 45-50sq" of port.
what are ur max dimensions to work with?
The max dimensions would be 37 wide 13 deep and open to height and that is with subs and port up. And i guess if I were to fire and port back it would be 37 wide 10 deep ? tall
2 DC level 2 12's
  • 1 month later...
I noticed that most of the slot ports seem to be about 4 inches wide or more. Is there anything wrong with going with a 1 or 2 inch slot port so that it doesn't have to be as long?
2 DC level 2 12's
  • Who's Online   0 Members, 0 Anonymous, 1485 Guests (See full list)
