Jmoney2544 Posted April 26, 2011 Report Posted April 26, 2011 What's the difference between component and 2 & 3 -ways speakers. are having external tweeters have any advantage over a 3-way speaker with it built in? Ill be running 5 1/4 2-ways or 5 1/4 component systems and 6x9's in the back. Amp" AQ90x4 What's do you guys think i should do? Car: 2002 Buick Regal Wiring: Knu Kolossus 1/0 + JL 4 Gauge Big 3: Stinger HPM 1/0 Alternator: Stock 135 Amp Batterys: Optima RedTop (Hood) XS D3100 (Trunk) HeadUnit: Pioneer DEH-4200UB Subs: (2) AQ HDC3 12's Sub Amp: AQ 2200D Sub Box: 4.6 Cubes @ 36hz Mids & Highs: (Front) Rockford Fosgate Power T1693 3-Way 6x9's Mids & Highs: (Rear ) Rockford Fosgate Power T152S 2-Way Component 5.25" Speaker Amp: AQ4x90 Sound Dampener : 75 Ft Fatmat
Robert8252 Posted April 26, 2011 Report Posted April 26, 2011 With components you can set your sound stage up better. Bring the vocals up to ear level where they should be and keep the midbass lower. Three way components do the same except now you can really set your sound stage right since the midrange and tweet will be your main stage up high at ear level and the midbass can be in the doors and such and not be as noticeable to where it's location is producing the sound. Now coax speakers have the same "idea", minus being able to aim your sound stage correctly, and usually not the same quality though and cheaper inline crossovers that can make some things sound sloppy and such. 2013 F150 Crew Cab Old Build Log Feedback 2013 F150 Equipment - Some Awesome Stereo Sound Making Stuff
Jmoney2544 Posted April 26, 2011 Author Report Posted April 26, 2011 With components you can set your sound stage up better. Bring the vocals up to ear level where they should be and keep the midbass lower. Three way components do the same except now you can really set your sound stage right since the midrange and tweet will be your main stage up high at ear level and the midbass can be in the doors and such and not be as noticeable to where it's location is producing the sound. Now coax speakers have the same "idea", minus being able to aim your sound stage correctly, and usually not the same quality though and cheaper inline crossovers that can make some things sound sloppy and such. what component set would be good for 90 watts for 5 1/4? Car: 2002 Buick Regal Wiring: Knu Kolossus 1/0 + JL 4 Gauge Big 3: Stinger HPM 1/0 Alternator: Stock 135 Amp Batterys: Optima RedTop (Hood) XS D3100 (Trunk) HeadUnit: Pioneer DEH-4200UB Subs: (2) AQ HDC3 12's Sub Amp: AQ 2200D Sub Box: 4.6 Cubes @ 36hz Mids & Highs: (Front) Rockford Fosgate Power T1693 3-Way 6x9's Mids & Highs: (Rear ) Rockford Fosgate Power T152S 2-Way Component 5.25" Speaker Amp: AQ4x90 Sound Dampener : 75 Ft Fatmat
