Is it possible to mount just the internals of a small 100 watt amp in my glove box ?? there will be nothing else in the glove box with it other than a small fan. Would it be safe , regardless of would it be smart, just would it be safe too ? It should work just fine.
IMAG0081.jpgIMAG0080.jpgampinternals.jpg----A horrible pic, but you get the idea !!
I always like to do something a little different and since this is such a small amp especially disassembled, i thought it would look awesome mounting just the internals since it all comes apart well and i would have the fan on it and maybe so some cool lighting to showcase it when you open the glove box !!
I would not use the amp without a heat sink on the output chip, it will over heat even with a fan, get a small block of aluminum for the chip. 8)
No warranty
95 civic
air-ride RE-5 slam specialties
4-18's Dc xlm2's tuned 35hz
2-1100.1's @ .35 each
2-SD 250.2 nano amps
3-deka 9a31 1-deka 35ah
2-250 amp alts/ Adjustable regulator
159 sealed @ dash 51hz
Just put a big heatsink on the mosfet and call it good, no need for the fan.
Hammerdown... 1%
  • Who's Online   0 Members, 0 Anonymous, 733 Guests (See full list)
