I dont know weather to get the...
AQ2200D (Underated)
or
BRZ2400.1 (CEA @ 2400 Watts)
This is the only thing getting in my way of wanting the aq, and also could i get true 2200+ watts of pure Unclipped Power on the aq?
Im afraid if i turn it up like 3/4 of the way on the knob it will start clipping and i will feel like i cant get the true 2200 watts outta it and only like 1700 or so
realize that no amp is 100% efficient so with that being said.. AQ line of amps all do rated power plus some but all that depends on your voltage,ohm load things like that. Also the gain knob is not a power button...Again THE GAIN KNOB IS NOT A POWER BUTTON, with that being said the aq is able of giving your the desired 2200 watts of power you desire but you must use an oscope to keep it clean
what do u mean it not a power button..wtf...its a gain knob, when did i say it was a power button...lol
i believe that he is referring to people using the bass boost to control the volume of the subwoofer. IMO
whats the difference between a gain or bass boost remote?
Car: 2002 Buick Regal
Wiring: Knu Kolossus 1/0 + JL 4 Gauge
Big 3: Stinger HPM 1/0
Alternator: Stock 135 Amp
Batterys: Optima RedTop (Hood) XS D3100 (Trunk)
HeadUnit: Pioneer DEH-4200UB
Subs: (2) AQ HDC3 12's
Sub Amp: AQ 2200D
Sub Box: 4.6 Cubes @ 36hz
Mids & Highs: (Front) Rockford Fosgate Power T1693 3-Way 6x9's
Mids & Highs: (Rear ) Rockford Fosgate Power T152S 2-Way Component 5.25"
Speaker Amp: AQ4x90
Sound Dampener : 75 Ft Fatmat
AQ2200D (Underated)
or
In all honesty i dont fully understand enough to give you a good answer. but from what i can think. is that it is used to adjust to the signal clippage.
such as low notes can cause more clipping than higher notes etc.. soo adjusting the bass boost helps you tweak the power so that your amp will send clean power to your sub.
(this is just a guess) lol i dont know for sure. but ive seen countless times that the bass boost is not a volume knob. i just never really asked why. so i will be following this to see if there is a much more educated answer
The IrishmanDCSig.jpgCheck out my build hereXL 4th order wall build logIn Progress:alpine cda HU4th order Bandpass2xl 15's1- ab 400.1 (gonna be two hopefully)4- Crescendo 8's2- xts crecendo supertweeters
2 sq super tweetsMb quart 4.125Mechman 270a alt1- xs D27003- xs XP3000
4- odessey pc1700seller feed back threadhttp://www.stevemeadedesigns.com/board/topic/136418-d-train-13k/
