ilovebass808 Posted April 29, 2011 Report Posted April 29, 2011 My friend just bought a t1d4 and a kenwood 1000 watt 2 channel amp. But he said that his fuse on the amp keeps popping. Could it be from being at the wrong ohm load on the amp? If it is what ohm load could I put it at? Check out my build! http://www.stevemeadedesigns.com/board/topic/129983-99-chevy-s10-build-log/
Azagtoth502 Posted April 29, 2011 Report Posted April 29, 2011 Maybe, could be too small a fuse. I'd check the wiring first. Could be a bare wire touching metal. pa-pa-platypus sorry not everybody has a companies nuts so far down their throat they catch every drop ball sweat when it falls
Dailyspl Posted April 29, 2011 Report Posted April 29, 2011 Yeah most likly a bad ground, or your power wire is cut somwhere and is grounding out 99 expedition Two 15 inch dc audio xls Ported box tunned to 34 hrtz Soundstream pcx.2000d(better amp soon) 0 gauge big three(soon) Yellow top,(more batts soon)
ilovebass808 Posted April 29, 2011 Author Report Posted April 29, 2011 His fuse on the amp is 30. Could it be also because it's 2 ohms bridged? I heard 2 channel amps are only stable at 4 ohms bridged. Check out my build! http://www.stevemeadedesigns.com/board/topic/129983-99-chevy-s10-build-log/
Azagtoth502 Posted April 29, 2011 Report Posted April 29, 2011 That sub can be wired at 2 or 8 ohm. As for the amp, look for the Kenwood manual to know. http://www.kenwoodus...Owners_Manuals/ pa-pa-platypus sorry not everybody has a companies nuts so far down their throat they catch every drop ball sweat when it falls
ilovebass808 Posted April 29, 2011 Author Report Posted April 29, 2011 I was just gonna wire the sub in series. So that it'll be wired at 8 ohms. Does that sound right? Check out my build! http://www.stevemeadedesigns.com/board/topic/129983-99-chevy-s10-build-log/
