MACnonsence6 Posted April 30, 2011 Report Share Posted April 30, 2011 so i bought this http://cgi.ebay.com/ws/eBayISAPI.dll?ViewItem&item=270718892321&ssPageName=STRK:MEWNX:IT#ht_1177wt_905 and i was wondering if this is the right stuff the only thing that scetches me out is how short the cure time is idk if ill have enough time to make sure i have everything for my recone set right Quote I picked up an MTX Sw1212 powered subwoofer today. This thing sounds amazing. 130 watts, 12" woofer with a passive 12" woofer tuned to 27 hz. Moving the pictures on the walls and my girl got wet from the bass when i showed her haha. Tonight should be good haha. Link to comment Share on other sites More sharing options...
fr34kout Posted April 30, 2011 Report Share Posted April 30, 2011 Where does it show the cure time? Normally with recones you line everything up, put the CA glue where you need it, spray the activator, then quickly push everything down. After that use clamps on the spider and surround and let it sit for 24 hours. Quote Link to comment Share on other sites More sharing options...
MACnonsence6 Posted May 1, 2011 Author Report Share Posted May 1, 2011 (edited) it says the cure time on the back of the bottle i already bought it a member in chat said it was the right stuff so i went ahead and got it cure times only 2 mins Edited May 1, 2011 by hifonics10 Quote I picked up an MTX Sw1212 powered subwoofer today. This thing sounds amazing. 130 watts, 12" woofer with a passive 12" woofer tuned to 27 hz. Moving the pictures on the walls and my girl got wet from the bass when i showed her haha. Tonight should be good haha. Link to comment Share on other sites More sharing options...
audiofanaticz Posted May 1, 2011 Report Share Posted May 1, 2011 Does it come with activator, without the activator it is pretty much just super glue! Also, that is NOT FOAM SAFE it says, so I probably wouldnt use it for gluing your surround!! http://fixmyspeaker.com/ProductList.php?CatID=7 Theres what you should get! Tho I dont like how they dont disclose the type of glue you are using, all glue is not created equal and some is better then others. All you know with the glue from FMS is it was bought in bulk and repackaged for smaller sales. Quote Link to comment Share on other sites More sharing options...
audiofanaticz Posted May 1, 2011 Report Share Posted May 1, 2011 cure times only 2 mins 2 minutes? LOL Umm now, it may bond in 2 minutes (where the activator was applied), but where ever the activator did not get sprayed will not usually cure for 24hours. If you use too much activator however, the glue will get hot and crack (like fiberglass resin with too much hardner) or the glue joints will turn white. depending on your ability to recone a woofer, you should be able to remove clamps with in 30-45minutes of spraying activator. BUT STILL DONT USE THE WOOFER FOR A GOOD 24HOURS TO BE SAFE! Quote Link to comment Share on other sites More sharing options...
MACnonsence6 Posted May 1, 2011 Author Report Share Posted May 1, 2011 thats odd the bottle doesnt say anything about it not being foam safe i sopose i could just use jb welb for the surround im Quote I picked up an MTX Sw1212 powered subwoofer today. This thing sounds amazing. 130 watts, 12" woofer with a passive 12" woofer tuned to 27 hz. Moving the pictures on the walls and my girl got wet from the bass when i showed her haha. Tonight should be good haha. Link to comment Share on other sites More sharing options...
audiofanaticz Posted May 1, 2011 Report Share Posted May 1, 2011 thats odd the bottle doesnt say anything about it not being foam safe i sopose i could just use jb welb for the surround im read the ebay auction you bought it from... Not safe for foam. For foam applications use epoxy or foam-safe CA. Quote Link to comment Share on other sites More sharing options...
MACnonsence6 Posted May 1, 2011 Author Report Share Posted May 1, 2011 thats odd the bottle doesnt say anything about it not being foam safe i sopose i could just use jb welb for the surround im read the ebay auction you bought it from... Not safe for foam. For foam applications use epoxy or foam-safe CA. ik i was just saying Quote I picked up an MTX Sw1212 powered subwoofer today. This thing sounds amazing. 130 watts, 12" woofer with a passive 12" woofer tuned to 27 hz. Moving the pictures on the walls and my girl got wet from the bass when i showed her haha. Tonight should be good haha. Link to comment Share on other sites More sharing options...
MACnonsence6 Posted May 1, 2011 Author Report Share Posted May 1, 2011 FUCK what other options do i have that i can pick up at walmart or advanced auto parts im getting my recone monday so im not waiting anylonger to order something else ive seen people recone subs on youtube with jbweld and epoxy Quote I picked up an MTX Sw1212 powered subwoofer today. This thing sounds amazing. 130 watts, 12" woofer with a passive 12" woofer tuned to 27 hz. Moving the pictures on the walls and my girl got wet from the bass when i showed her haha. Tonight should be good haha. Link to comment Share on other sites More sharing options...
audiofanaticz Posted May 1, 2011 Report Share Posted May 1, 2011 this is the glue I use, cant say what it is tho, and its bought in bulk. but some of the better stuff ive worked with. Quote Link to comment Share on other sites More sharing options...
