My way to 153.2dB @ 26Hz. Ford Express with 4x 15"
Test fit of the baffel .
Port.
Personal bests:
dB Drag: 163.4dB (2004)
Propper Droppers: Average: 150.5dB. Peak: 153.2dB @ 26Hz (2010)
EASCA dBL: 152.2dB (music)(2010)
Forgot my camera so just pics from my phone..
Needed more 2"x3"...
For the next two pics, don´t ask why it was taken.. I don´t know ;)
Don´t have the space I need for the amps so I had to improvice, the PG and the B2 amp under that will be ½" into the 2"x3" so I can close the back doors... It´s TIGHT!
I will have two more B2´s between the braces.
Personal bests:
The bracing will be screwed to the backwall.
Put this in the sealed box to brace and to have an easy way to know that my baffle will be in the right place.
Personal bests:
I had to cut up the port to be able to get inside the box, the port was 8" and now it´s ~10", I will add two boards to the port to get it back to 8".
I added some 2"x3" to the portwall.
The others side.
And then I added some boards.
When it was time to put in the baffle I had called my friend Mattias to give me some help since I had a feeling that it would be hard to get it inside the box.
I was right :D
Mattias weigh ~90kg and the baffel didn´t move at all when he jumped on it..
Personal bests:
But we didn´t give up that easy... :D
Finaly the baffle was in.
I used this 2"x3" and a hammer to get the baffle in, as you can see it needed some force to get it done .
Personal bests:
A little video of the box.
http://s709.photobucket.com/albums/ww99/ExtraKim/Expressen/?action=view¤t=DSCF0743.flv
(The box are on it´s side.)
Some bracing.
I bought this some days after I started to build the box when my other screws ran out and then I bought 150 75mm screws... And yesterday I opened my fifth glueblottle ;)
Side
Floor
Roof
Others side.
Personal bests:
Front, the "portblocker" to get the port size back.
Just first layer with paint, I have some ideas for the inside but I want to test the box first.
The box are VERY heavy right now, used this to flip it on the side.
Had to get the box out from the garage today and my mom and I had big problems moving it. But problems just need to be solved so I used tubes to roll the box on :D
The tubes we used to move the box.
My moms dog didn´t like the box...
Personal bests:
Personal bests:
