gotFI? Posted October 1, 2007 Report Share Posted October 1, 2007 my powerbass xa-3000d is ran @ 1 ohm. the amp is making a one tone "burp". no music. what is the problem? :mad: Link to comment Share on other sites More sharing options...
finkster Posted October 1, 2007 Report Share Posted October 1, 2007 do u mean it does nothing but play one tone or it does one short burp and it cuts out? Check ur wiring, fuses, gains set right? DAT 4125------>RE XXX comps active Eclipse cd7000 I serve drunks for a living Link to comment Share on other sites More sharing options...
gotFI? Posted October 1, 2007 Author Report Share Posted October 1, 2007 do u mean it does nothing but play one tone or it does one short burp and it cuts out? Check ur wiring, fuses, gains set right? it plays one tone when i turn up the gain. then i have to turn it down b/c its so loud. i mess with the controls, no differance. would the rca and power cable beside eachother cause this. this is a bass tone like noise. not a humming. what to do? :mad: Link to comment Share on other sites More sharing options...
gotFI? Posted October 1, 2007 Author Report Share Posted October 1, 2007 anyone?????? Link to comment Share on other sites More sharing options...
David Posted October 1, 2007 Report Share Posted October 1, 2007 ok first lets look at the whole system H/U ( which brand) Mids/highs amp sub amp (powerbass x3000) when you turn the H/u on all you get is a tone from the amp, it plays through the woofer or from the amp itself? Link to comment Share on other sites More sharing options...
gotFI? Posted October 1, 2007 Author Report Share Posted October 1, 2007 ok first lets look at the whole systemH/U ( which brand) Mids/highs amp sub amp (powerbass x3000) when you turn the H/u on all you get is a tone from the amp, it plays through the woofer or from the amp itself? bass tone is playing through the woofer. sub amp, powerbass xa-3000d. 0 gauge running from the batt up front with a 150 amp fuse to the amp. ground is good. no music at all. Link to comment Share on other sites More sharing options...
David Posted October 1, 2007 Report Share Posted October 1, 2007 does it play a tone soon as you turn the headunit on? if the gain is turned allthe way down does it still make the tone? Link to comment Share on other sites More sharing options...
gotFI? Posted October 1, 2007 Author Report Share Posted October 1, 2007 does it play a tone soon as you turn the headunit on?if the gain is turned allthe way down does it still make the tone? does not make the tone when the gain is down. only when its up. whats a H/U? Link to comment Share on other sites More sharing options...
David Posted October 1, 2007 Report Share Posted October 1, 2007 your head unit ( deck, radio, cd player) disconnect the RCA's then turn it up and tell me what it does Link to comment Share on other sites More sharing options...
