I am in the process of installing my sound deadener throughout my vehicle at the moment and want to install some luxury liner afterwards.
For a mid-size 4 door sedan, how many feet would you recommend I use for the flooring?
Also what would you recommend to fill in the door panels with? Will Polyfill work?
Current Build:
1999 Tahoe #ComingSoon
Previous Build(s):
Crossfire Magnum
5k Pontiac G6 GT
To completely cover the floor of a typical 4 door sedan, you need approximately 36 sq. ft. (four sheets). Unlike CLD mats which require as little as 25% coverage, MLV products should completely cover the entire surface to create one continuous and impenetrable layer.
What are you trying to achieve with filling the door panels? Or in other words, what problem are you having? Rattles? Excessive noise?
Have a question about Second Skin? E-Mail me!
Alright thank you!
Actually I don't have any problems with the doors at the moment since I haven't installed the speakers LOL!
I'm looking to create the best enclosure for components.
I'm just doing all the work now before I get my equipment on the doors.
Current Build:
Previous Build(s):
Crossfire Magnum
5k Pontiac G6 GT
Ah, ok.
Once the doors are properly deadened and all of the access holes in the door panel are sealed up they isn't much of any need to stuff them.
Yes, it can be as simple as installing sound deadening material over the hole.
Some people go as far as installing panels made from aluminum flashing, MDF, or other hard materials and screwing them onto the door and sound deadening over them. Thats what I did... :D
You're welcome!
if you have any other questions or need some tips, you know where to ask!
