drumminian Posted May 5, 2011 Report Posted May 5, 2011 Okay I drive a 1997 toyota tercel.. stock alt, big 3 upgrade, yellow top, bp1200.1 amp, on a fi BL. Okay so this is a weird problem I have been having, while driving whenever I either press the brake/turn signals/headlights, my headunit will turn off and back on again. I haven't been able to figure out what it was thought it was the ground for the headunit but that wasn't it. what all should I check? I also get pretty low voltage randomly like <12 sitting idle and even driving with no bass heavy music playing. And the car somethings seems if the battery gets unconnected when I start it like i put th key in turn and as soon as the engine starts to crank I loose power.... very weird I need your help smd Alpine CDA-9887 15" FI BL JBL BP1200.1 Rockford Fosgate p142 4" front Rockford Fosgate p1S652 6.5" rear Optima D35 yellow top under hood Big 3 all in a 1997 Toyota Tercel
Gotloud555 Posted May 6, 2011 Report Posted May 6, 2011 Okay I drive a 1997 toyota tercel.. stock alt, big 3 upgrade, yellow top, bp1200.1 amp, on a fi BL. Okay so this is a weird problem I have been having, while driving whenever I either press the brake/turn signals/headlights, my headunit will turn off and back on again. I haven't been able to figure out what it was thought it was the ground for the headunit but that wasn't it. what all should I check? I also get pretty low voltage randomly like <12 sitting idle and even driving with no bass heavy music playing. And the car somethings seems if the battery gets unconnected when I start it like i put th key in turn and as soon as the engine starts to crank I loose power.... very weird I need your help smd Did you had this problem before you did big 3 or any electrical upgrade? Having that low voltage bad for the vehicle feul pump. How's the condition of the battery and connection on the alternator?
