412 CVX Posted May 10, 2011 Report Posted May 10, 2011 so i make 2- port pieces? cvx yeah i plan to do resin 45's and no other bracing because im doing a double baffle. baffle isnt counted for because its on the outside and will make it so the subs are "flush" with box and where the port is ill be 45ing the 2nd baffle if that makes sense. you mean like a flared port? Quote Just say no to Ground Pounder Customs. My temp system build log More box buildssome cars do over 170db with one sub, so clearly my two 12"s can do that in my car, with my knowledge too! look out bitches! I'm with captain stupid.
Bumpindemlowzz Posted May 10, 2011 Author Report Posted May 10, 2011 (edited) Haha i dont know what i was saying earlier im tired. I would be double baffling the top which wouldnt effect the port because its on a different side. i was cornfused... If you cant tell by the drawing its subs up port middle back Edited May 10, 2011 by Bumpindemlowzz Quote 2010 Silverado 18" DC XL 18 DC 2k XS Power Batts
Bumpindemlowzz Posted May 20, 2011 Author Report Posted May 20, 2011 Im not building this anymore due to getting a different sub. Subs a 18" Dc XL Im using torres calc I want about 5 to 5.5 cubes tuned to 32-34hz using either aeroports or slot port. Max measurements are 17"H x 37"W x 24"D. I would like to use aeros because it would be super easy to change tuning. My question is when i calculate tuning with the 2 6" aeros port area is really low. Is this normal with aeros? Quote 2010 Silverado 18" DC XL 18 DC 2k XS Power Batts
412 CVX Posted May 22, 2011 Report Posted May 22, 2011 Im not building this anymore due to getting a different sub. Subs a 18" Dc XL Im using torres calc I want about 5 to 5.5 cubes tuned to 32-34hz using either aeroports or slot port. Max measurements are 17"H x 37"W x 24"D. I would like to use aeros because it would be super easy to change tuning. My question is when i calculate tuning with the 2 6" aeros port area is really low. Is this normal with aeros? the port area per cube is based off of 9-12" per cube. the tuning shouldn't be different because of the aeros Quote Just say no to Ground Pounder Customs. My temp system build log More box buildssome cars do over 170db with one sub, so clearly my two 12"s can do that in my car, with my knowledge too! look out bitches! I'm with captain stupid.
matt402 Posted May 22, 2011 Report Posted May 22, 2011 id make the box 6 cubes or a lil more & do 3 6" aeros. Quote
