Can someone design me a box for 4 kicker cvr 12s, they will be firing up, port firing towards the tailgate. The size of the area it can be in is about 45 wide, over 20 high and about 45 long
Edited by Brandon M
Will this work? Port wise, I have no idea what Im doing
what kind of port are you trying to put in the box, a circle or square/rectangle? because thats the way you have it set up right now. if you want a square or rectangle port you only use the height and width and length. for circle ports you only use # of ports and diameter and length.
Not nearly enough port area per cube. You want around 16sqin per cube.
You've also left woofer displacement blank, as well as the number of common walls you want to do.
Edited by Supercharged DDs
Any chance you can give me a hand with this? This will be the first box i've built besides a basic sealed enclosure a few years back
I'll try to get something done tomorrow, I dont have access to my computer at the moment.
