ham4864 Posted May 17, 2011 Report Share Posted May 17, 2011 is it a good idea to run the mids off a amp and the highs off the head units.I'm 99% sure that deck does active x-over so i can safely set the tweeters frequency. 2009 bmw 5 series Head Unit Stock Amplifier-JL Audio JX 360/4 Processor- Audiocontrol LC6 Link to comment Share on other sites More sharing options...
Skullz Posted May 17, 2011 Report Share Posted May 17, 2011 No it does not have an active crossover, you'll need to use your amps crossover or buy one. 01 Ford focus ZX3 Pioneer AVH-X491BHS PPI PC 4800.2 Morel Maximo 6.5" x2 Link to comment Share on other sites More sharing options...
ham4864 Posted May 17, 2011 Author Report Share Posted May 17, 2011 No it does not have an active crossover, you'll need to use your amps crossover or buy one. ok thank you.my amp frot ch goes to 4500Hz is that enough. 2009 bmw 5 series Head Unit Stock Amplifier-JL Audio JX 360/4 Processor- Audiocontrol LC6 Link to comment Share on other sites More sharing options...
Skullz Posted May 17, 2011 Report Share Posted May 17, 2011 Depends on the amp and number of channels the amp has, if you have a 4 channel amp you should be able to run the tweeters off 2 channels and the mids off the other 2 channels and for a 2 channel you'll only be able to run it high or low. 01 Ford focus ZX3 Pioneer AVH-X491BHS PPI PC 4800.2 Morel Maximo 6.5" x2 Link to comment Share on other sites More sharing options...
ham4864 Posted May 17, 2011 Author Report Share Posted May 17, 2011 Depends on the amp and number of channels the amp has, if you have a 4 channel amp you should be able to run the tweeters off 2 channels and the mids off the other 2 channels and for a 2 channel you'll only be able to run it high or low. sorry for that yes is a 4ch amp soundstream rub4.600 and the front ch HPF goes to 4500Hz. 2009 bmw 5 series Head Unit Stock Amplifier-JL Audio JX 360/4 Processor- Audiocontrol LC6 Link to comment Share on other sites More sharing options...
