Jmoney2544 Posted May 18, 2011 Report Posted May 18, 2011 Would 2 6" Aeroports be fine with a 8 cubic foot box with 2 HDC3 15's? Car: 2002 Buick Regal Wiring: Knu Kolossus 1/0 + JL 4 Gauge Big 3: Stinger HPM 1/0 Alternator: Stock 135 Amp Batterys: Optima RedTop (Hood) XS D3100 (Trunk) HeadUnit: Pioneer DEH-4200UB Subs: (2) AQ HDC3 12's Sub Amp: AQ 2200D Sub Box: 4.6 Cubes @ 36hz Mids & Highs: (Front) Rockford Fosgate Power T1693 3-Way 6x9's Mids & Highs: (Rear ) Rockford Fosgate Power T152S 2-Way Component 5.25" Speaker Amp: AQ4x90 Sound Dampener : 75 Ft Fatmat
fritosaregood Posted May 18, 2011 Report Posted May 18, 2011 Would 2 6" Aeroports be fine with a 8 cubic foot box with 2 HDC3 15's? It will most likely sound good, but wont get crazy loud. you'll also be able to extend below tuning well, but will get some port noise. I would step up to 3 6's or 2 8's for more output. seller feedback: http://www.stevemeadedesigns.com/board/ind...showtopic=61719 http://www.stevemeadedesigns.com/board/ind...showtopic=68281 build log: http://www.stevemeadedesigns.com/board/index.php?showtopic=44800 Gf's build: http://www.stevemeadedesigns.com/board/topic/54346-kickergirls-camaro-new-box-pg-5/#entry753970
Jmoney2544 Posted May 18, 2011 Author Report Posted May 18, 2011 Would 2 6" Aeroports be fine with a 8 cubic foot box with 2 HDC3 15's? It will most likely sound good, but wont get crazy loud. you'll also be able to extend below tuning well, but will get some port noise. I would step up to 3 6's or 2 8's for more output. could i fire aeroports on the top of my box towards the roof if the subs are facing the rear of my trunk? Car: 2002 Buick Regal Wiring: Knu Kolossus 1/0 + JL 4 Gauge Big 3: Stinger HPM 1/0 Alternator: Stock 135 Amp Batterys: Optima RedTop (Hood) XS D3100 (Trunk) HeadUnit: Pioneer DEH-4200UB Subs: (2) AQ HDC3 12's Sub Amp: AQ 2200D Sub Box: 4.6 Cubes @ 36hz Mids & Highs: (Front) Rockford Fosgate Power T1693 3-Way 6x9's Mids & Highs: (Rear ) Rockford Fosgate Power T152S 2-Way Component 5.25" Speaker Amp: AQ4x90 Sound Dampener : 75 Ft Fatmat
fritosaregood Posted May 18, 2011 Report Posted May 18, 2011 Would 2 6" Aeroports be fine with a 8 cubic foot box with 2 HDC3 15's? It will most likely sound good, but wont get crazy loud. you'll also be able to extend below tuning well, but will get some port noise. I would step up to 3 6's or 2 8's for more output. could i fire aeroports on the top of my box towards the roof if the subs are facing the rear of my trunk? sure seller feedback: http://www.stevemeadedesigns.com/board/ind...showtopic=61719 http://www.stevemeadedesigns.com/board/ind...showtopic=68281 build log: http://www.stevemeadedesigns.com/board/index.php?showtopic=44800 Gf's build: http://www.stevemeadedesigns.com/board/topic/54346-kickergirls-camaro-new-box-pg-5/#entry753970
Jmoney2544 Posted May 18, 2011 Author Report Posted May 18, 2011 Would 2 6" Aeroports be fine with a 8 cubic foot box with 2 HDC3 15's? It will most likely sound good, but wont get crazy loud. you'll also be able to extend below tuning well, but will get some port noise. I would step up to 3 6's or 2 8's for more output. could i fire aeroports on the top of my box towards the roof if the subs are facing the rear of my trunk? sure i have about 3" from the top of my box till the roof of my trunk. is that enough room to push air outta the aeroports? Car: 2002 Buick Regal Wiring: Knu Kolossus 1/0 + JL 4 Gauge Big 3: Stinger HPM 1/0 Alternator: Stock 135 Amp Batterys: Optima RedTop (Hood) XS D3100 (Trunk) HeadUnit: Pioneer DEH-4200UB Subs: (2) AQ HDC3 12's Sub Amp: AQ 2200D Sub Box: 4.6 Cubes @ 36hz Mids & Highs: (Front) Rockford Fosgate Power T1693 3-Way 6x9's Mids & Highs: (Rear ) Rockford Fosgate Power T152S 2-Way Component 5.25" Speaker Amp: AQ4x90 Sound Dampener : 75 Ft Fatmat
moto211 Posted May 18, 2011 Report Posted May 18, 2011 Have you thought about a square port, more area , you can flare the edges CHECK OUT MY YOU TUBE PAGE http://www.youtube.com/user/motoxxx211?feature=mhee[/size]
