turbo start 16 volt AMG charger.
The TurboStart AGM Series 16 volt charger is fully automatic with a 25 amp output and has been upgraded over the standard TurboStart 16 volt charger to be able to charge either AGM or flooded 16 volt types. A charger circuit board chip is shipped with the AGM Series 16 volt battery to allow existing TurboStart 16 volt users to upgrade their standard TurboStart charger to the new AGM Series charger design. An in line step down voltage reducer is also available for use with the AGM Series 16 volt battery which allows you to run 14 volts to desired components.
Email: [email protected]
Edited by Money man...
FOR SALE $100.00 Each. Total 11 each
The sealed TurboStart AGM Series 16 volt battery utilizes the latest state of the art AGM (Absorbent Glass Mat) separator technology. Because they can't leak, even if the container is damaged, we're able to ship our TurboStart AGM Series types fully charged so the battery is ready to go when you get it.
The unique valve regulated design ensures that each cell operates at a slight positive pressure allowing the hydrogen and oxygen gas recombination process to occur within the battery which virtually eliminates on - charge gassing.No more maintenance and no more acid mess!
High purity lead grids incorporated into the new "Starved Electrolyte" design gives the TurboStart AGM Series maintenance free battery additional cold cranking amps as well as extra reserve capacity over the conventional TurboStart 16 volt flooded battery design with no increase in battery weight. More power, more capacity…no more weight!
Redesigned from the ground up, the TurboStart AGM Series 16 volt maintenance free battery has a new, low profile "Bolt-in" terminal design for lug style or buss bar terminal hook ups...perfect for multiple battery SPL set ups!
This topic is now closed to further replies.
