Remote Turn On
JWBryant
Ok i have two Dual brand amps and they are hooked into a Dual headunit I have recently been trying to clean up the setup so it will look nicer. and I tried to hook up power to the amps and they will not turn on they are properly grounded and everything it is simply the remote turn on that is not working. I know this because if I bridge the positive and the remote the amp lights up. The remote turn on was not working in the back so I then tried to hook it up to the ignition switch that the radio was hooked up to and it worked.., soon this didnt work either but, the radio still turned on so it has to be something on the amp. Should I be using different size wire, or something? Any help is greatly appreciated.
Basshead-in-Training
it sounds like u have a bad remote wire run a new wire to the amps and make sure that its hooked up to the blue wire with the white stripe on the back of the headunit
89 Chevy Caprice (is under construction)
dual alts
4/0 welding cable for wire
red top under hood 3 yellow tops behind the front seat ( who needs a back seat anyways lol)
big 3 of course
Eclipse 3000
interiors are getting rebuilt now
2 crescendo bc2000
2 shocker sig 12s
rebuild pics
Mine is dark blue on the back of the headunit but I'll givie it a shot.
I changed the wire and it worked!! I dont know how they are identical wires but thank you.
no prob man
dual alts
big 3 of course
Eclipse 3000
2 crescendo bc2000
2 shocker sig 12s
rebuild pics
Ok it stopped wworking again so I changed the wires again. Yes it worked again, so then I unkooked it and ran it under the plastic coverings on my truck to the amp, pluged it in and it didn't work again. The wire is fine it just doesnt seem to be conducting the electrical current provided by the ignition. I have this wire next to rca cables and some speaker wires, the +positive is on the other side. I can take pictures if I need to but that is what the problem is.
what do you have the remote wire hooked up to ? take and hook a test light or DMM to the end of the remote wire that is supposed to go to the amp, and turn the key on and make sure u have power and is shutting off once u turn the key off. the wire might be fine there could be a problem with the amp thoe
dual alts
big 3 of course
Eclipse 3000
2 crescendo bc2000
2 shocker sig 12s
rebuild pics
I tried what you said and it turned out I wasnt getting power from the beginning from the headunit to the remote wire. It just so happens that if I connected the wire with electrical tape it didn't conduct the current for some odd reason. So I used a connector pinched the wires on and now it is conducting electricity... Bad electrical tape I guess. Thanks for the Help
  • Who's Online   0 Members, 0 Anonymous, 756 Guests (See full list)
