tygixxer60 Posted May 23, 2011 Report Posted May 23, 2011 i have two kicker cvx 122 wired 2 ohms, 4.6 ft3 and tuned to 32hz with a kx2500.1 turned up to 63.6 volts 2000rms, and i just competed and got 144.5dbs,now when i was competing i had 30 sec and they had told me to start at 52hz and then they said higher and the db was going down so i ignored them and jumped down to 46 and the dbs jumped from 139 to 144, so my question is what should be the best hz to play when competing or where should i start and work my way up to? thanks
fecupe2001 Posted May 23, 2011 Report Posted May 23, 2011 i have two kicker cvx 122 wired 2 ohms, 4.6 ft3 and tuned to 32hz with a kx2500.1 turned up to 63.6 volts 2000rms, and i just competed and got 144.5dbs,now when i was competing i had 30 sec and they had told me to start at 52hz and then they said higher and the db was going down so i ignored them and jumped down to 46 and the dbs jumped from 139 to 144, so my question is what should be the best hz to play when competing or where should i start and work my way up to? thanks box peak doesn't have anything to do with car peak, they told you to burp around 52 hz thinking you could get a good score, but if your box is tuned so low and it's so god damn big, i wouldn't try anything higher than 44 hz depending on the car, just speaking basic things out, i could say that your peak might be something like 40-43 hz, but you need a sensor to try that out, would be easier for you to do it before a comp, just saying... I´m the SPL Gains topic creator!! wanna get louder?? check this: SPL Gains. Panamenian 2009 & 2010 & 2014 Bass Race 149.9 Champion! 2 15" subs and a 2K wired at 1 ohm, http://www.stevemeadedesigns.com/board/topic/167788-fecupe2001-2-15s-on-a-2k-video-on-page-3/ 8 Massive 15" subs and small power, http://www.stevemeadedesigns.com/board/topic/179296-fecupe2001s-8-15s-4th-order-bandpass-wall/
skittlesRgood Posted May 23, 2011 Report Posted May 23, 2011 do a sweep and the term lab will tell you the peak frequency. otherwise, start at 32 and jump up a few frequencies at a time until the score starts to go down. If I answered you in a well mannered, informative way, you asked a good question or had a good attitude. If I was an asshole, you asked a stupid question or you had a fucktard attitude... or I was in a bad mood. Team BassickHU: Pioneer AVIC Z110Front: Peerless SLS 6.5", Peerless HDS 4", Rainbow tweeter - running activeAmp: JL HD600/4 and DC 4 channel (bridged to midbass)Processor: JBL MS-8Subs: 2x 12" AA MayhemsAmp: DC 3kElectrical: DC power 270xp alt. 1/0 big 4. XSpower D3400 and six D680s. http://www.stevemeadedesigns.com/board/topic/121795-29-update-the-buick-is-getting-a-rebuild/ Top career scores: DBdrag 151.7 MECA SQ 82.25My SOTM build Yeah. im pretty sure they dont warranty retarded people.
