dmanson Posted October 11, 2007 Report Share Posted October 11, 2007 Yup, just looked at the subs. They are Dual 4 ohm. make sure it says that for both subs bro. you are good to go man. if you go to www.rockfordfosgate.com, you can play with the woofer wizard, select two subs, put in dual 4 or 4X4 ohm and it will show you how to wire them to get a 1 or 4 ohm load bro. good luck and post pics. 2-DC 15XLM2 D.7s 1-DC 5K amp (1) XS Power D6500(UNDERHOOD) and (1) XS3000(REAR) 3 runs 1/0ga for power and 2 runs of 1/0ga for negative. (2)-RFT165s components, ...... 4 separate 1 inch tweetersRF T600-2(fronts) Punch 450.4(rear) Audiocontrol 3.1. DC power 260amp alternator w/MLA Module Link to comment Share on other sites More sharing options...
Duece22 Posted October 11, 2007 Author Report Share Posted October 11, 2007 Thanks alot, both subs are dual 4 ohm =D 2008 Hummer H3 x2 Sundown Audio Nightshade V2 12s x1 Sundown Audio 3000D Link to comment Share on other sites More sharing options...
dmanson Posted October 12, 2007 Report Share Posted October 12, 2007 Thanks alot, both subs are dual 4 ohm =D you are more than good to go then man. be sure to run 1/0 gauge and nothing less. 2-DC 15XLM2 D.7s 1-DC 5K amp (1) XS Power D6500(UNDERHOOD) and (1) XS3000(REAR) 3 runs 1/0ga for power and 2 runs of 1/0ga for negative. (2)-RFT165s components, ...... 4 separate 1 inch tweetersRF T600-2(fronts) Punch 450.4(rear) Audiocontrol 3.1. DC power 260amp alternator w/MLA Module Link to comment Share on other sites More sharing options...
jockin my styLez Posted October 23, 2007 Report Share Posted October 23, 2007 Link to comment Share on other sites More sharing options...
Team Maxxsonics John Posted October 24, 2007 Report Share Posted October 24, 2007 If you have any problems, call Maxxsonics at 847-540-7700 and ask for tech support. They will take care of you. Link to comment Share on other sites More sharing options...
