Quick Electrical Question..
1. Will adding a deep cycle battery be better than the original factory starter battery? I mean by will it help keep better voltage? I may get a new deka battery. I dont know what size yet i guess whatever is the biggest size that can go into a 97 ford explorer. I dont know that was a stupid question i guess it depends on the Amp hours :shrug:
2. Also so many people have me so confused about fusing. I thought i had it. I was told by multiple people to fuse the inline fuse holder with at least 150 amp using this wire.http://www.knukonceptz.com/productDetail.cfm?prodID=KFX4BL Which is the capable load. But then i got another person telling me to fuse it with a 100 amp fuse. The amp will be an AQ1200 with i believe 3 40 amp fuses on the amp = 120
So what size fuse do i use? Sorry for the post count. I thought you used the max rating of the wire :shrug:
You know how you avoid that? Man the fuck up and bang her best friend sister mom cousin worst enemy and never look back.
JUST SAY ANTI-AUDIOPIPE
a bigger battery will obviously help. If you're having major voltage drop then it'll catch up to you and you'll still have that problem.
I forget what the max amps are to 4 gauge. Just use the biggest for the 4 gauge. I think 150 is correct.
2006 Nissan Z Track.
My Feedback Thread
  • Who's Online   0 Members, 0 Anonymous, 873 Guests (See full list)
