Great idea on the fans, too many installs dont use that easy and cheap idea.
I have an idea for you, you have 2 fans that are bigger than the other 2. Use one big and 1 small on each side so the output will match and wire them in opposite so that you one side will pull air in and the other side and push it out. Ive done it for years :popcorn:
Is the box for the 18 going to cover the fans?
Does this smell funny to you? Its your sister :roflmao:
at finnish forums i got question about folded -horn -type of an enclosure, and i took the idea abit further.
this will not be manufactured, but it is just an idea :D
T-line enclosure in a VOLVO. :D
tho i need room inside my trunk so it will olny be an idea for someone else :D
it will be like this:
i will switch fans 1good 1 bad to each side like you said. i was thinking of doing it at first place, but i tend to forgot things while i do stuff :D
also for now there is enough holes under to get the air needed, but when i dynamat this b*tch there won't be any air to replace, so fans won't work that well. then i will change the fans to the right ones to suck in and left ones to blow out. left ones are the nearest to both amps so the heat will be there.
box is going to be roughly in centimeters: 50x47x100 on the outside, inside 45x42x95, so it is 179litres big, and with driver displacement and port displacement we are talking about something like 150 to 165litres internal volume. i haven't calculated it yet. i will measure it precicely.
the box (shown in red) can be opened when the box is in, there will be 5 to 7 cm space between the enclosure and the box's edge. (can be seen in picture)
updates!
i remade the bassknob to fit in original VOLVO's panel
break it open
not that big
gief some knife into the panel
easy!
some glue and let it stay overnight.
if you glue and pop it in the glue will fume itself and make a CSI -trick where your fingerprint's grease will go white.
i let it dry in peace, don't want to have white fingerprints all over my car
some clamps will help it to glue in
next day: still works!
cool. i might rip off that "MAX/MIN" sticker, but it will do for now
then i made RCA -reader cable.
so i can sit in front seat with DMM and turn up volume meanwhile the wire is hooked into SUB AMP's RCA.
also installed a relay at back so the fan's don't take their positive from radio's RMT
radio controlls the relay and +12V comes from the back battery.
then i did a datasheet from my headunit to find out where it disorts.
i played song: 50Hz -5DBFS so it is +2dB lowder than normal song.
DATA!
there is Voltage from RCA, and dB / volume, so everytime i turn up volume i took the voltage from RCA, so when the raise of voltage is not 2dB or 1dB compared to the last one the signal starts to disort.
so i can play music with 30/35 whitout disortion.
i gotta find a -6DBFS 40Hz song. but can't find.
updates!
tuned ma front grill
front is now 33% done, i'm thinking about to change the yellow turnsignals to white and custom -build front bumper. not a "TUNING" -type of a predator -mask, but Bross -bodykit, so it looks original, but alittlebit diffirent.
O_o
there it is!
nice big magnet :)
3x 1"
Autostudio's newest biggest sub.
Autostudio Reference Unlimited 18" with 3" aluminium voicecoil. DVC 1ohm.
local HIFI -shop's decals. perfect size for MY VOLVO!
the basket looks like SPL Dynamics.
3" DD's voicecoil.
NIIIIICCEE!!!
1500WRMS 5000W peak.
spider is dual or 3x, it IS SO RIDGID!
and last, but not least!
HOHOHO!
stay tuned!
i took some closeups from the sub
without rubber around the magnets 22cm
with rubber 22,8-23cm
specs sofar what i have found:
AutoStudio Reference Unlimited-series 18" subwoofer
Size 18"
3" flat aluminum voice coil (made in USA) DD?
RMS 1500W
MAX 5000W
Impedance 2 x 1 ohm
installing depth 250mm
magnet diameter 230mm
weight 23kg
i'm gonna order tomorrow my enclosure. will be cut from plywood, roughly 179l brutto to 200l brutto, we'll see.
:clapping: Damn that looks nice man, cant wait to see it installed. :popcorn:
Back to the fan post.... use the fans Closest to the amps to pull air in as the outside air will be cooler than the air already inside the amp rack. I've seen a few degrees difference in swaping the order of push pull :shrug:
Have fun
  • Who's Online   0 Members, 0 Anonymous, 825 Guests (See full list)
