crunkjuice1 Posted June 6, 2011 Report Posted June 6, 2011 I am running power from rear battery to amp. My question is will I be ok with 24in from battery to the fuse holder (300A fuse)then from there 56in to amp? Or do I run 12in from rear battery to fuse holder then a run to amp?
BJD3 Posted June 6, 2011 Report Posted June 6, 2011 I am running power from rear battery to amp. My question is will I be ok with 24in from battery to the fuse holder (300A fuse)then from there 56in to amp? Or do I run 12in from rear battery to fuse holder then a run to amp? If it were me, I'd fuse the wire. Though its a short run, if the wire exits the amplifier somehow and contacts ground, you have nothing protecting that wire. I may be overly cautious though. Anti Peel and Seal...lol You may be offended by the above. Don't take it personally, I'm just abrasive. 2002 Buick Park Avenue DC Level 4 M2 12 D2 Car Audio Bargain 1600.1 Eclipse CD3200 ~2 cubes @ 34 hz. Stinger Roadkill Expert
crunkjuice1 Posted June 6, 2011 Author Report Posted June 6, 2011 Thanks for at least taking a shot at my question.
