walwalka Posted June 10, 2011 Report Posted June 10, 2011 Recently my car has not been starting because of a dead battery, I replaced the battery same issues. I determined it was the alternator, We got into replace the alternator and realized the the charging cable was broke. I re-crimped and soldered a ring terminal onto the battery cable and such well it happened again today. I'm wondering what the charging cable connects to in between the alternator and the battery? I drive a 2003 honda civic SI with the K20A3 motor, if i can figure out what it connects to I can build a new cable fresh and not have any other issue. The alternator data cable is fine, and the battery light doesn't come on. Also the alternator place where I live tested the alternator on the test bench and it is fine, charging at 14.6v. 2010 Honda Civic LX / Deck: Kenwood DDX371 / Front Highs: Crescendo RTS-1 / Front Mids: Silver Flute 6.5's / 4 channel: DC Audio 90.4 / Sub: Fi 15in SP4v2 / Sub amp: Taramps HD 5000 / Power wire: Knukonceptz OFC 1/0 / Deadener: Audio Technix 60 mil / Batteries: XS Power D5100R / Rear bank: TBD / Alternator: Singer 240a hairpin
Louisiana Bass Posted June 10, 2011 Report Posted June 10, 2011 Why not just do a run of 0 gauge from positive on battery to positive on alternator? N8. No homo...unless you want there to be.
walwalka Posted June 10, 2011 Author Report Posted June 10, 2011 Because I don't know if the charging cable connects to anything in between the alternator and the battery. 2010 Honda Civic LX / Deck: Kenwood DDX371 / Front Highs: Crescendo RTS-1 / Front Mids: Silver Flute 6.5's / 4 channel: DC Audio 90.4 / Sub: Fi 15in SP4v2 / Sub amp: Taramps HD 5000 / Power wire: Knukonceptz OFC 1/0 / Deadener: Audio Technix 60 mil / Batteries: XS Power D5100R / Rear bank: TBD / Alternator: Singer 240a hairpin
Gotloud555 Posted June 13, 2011 Report Posted June 13, 2011 All honda motor wouldn't have no issue with big 3. The k20 actually one the fastest motor in Honda.. Just add the 0 gauge cable to alternator and fuse the it beside the battery.. Not that hard.. Just make sure the positive cable connected properly on the alternator..
