I don't want to sale this amp but I need a new alt. I paid $ for the amp asking $435 shipped in cont. US. Taking a loss in what I paid and the fact that I wont get to run it.
1/0 AWG power/ground connectors
2/4 channel switch
24dB/octave crossover
Audiophile grade speaker connections
Blue L.E.D. Stealth Signal Meters - monitors signal with simulated VU needle
MOSFET output stage
MOSFET power supply
RCA pass-thru
Description
CEA-2006 Compliant
Number of Channels 4
Rated Power
(RMS Continuous Power) 150 Watts x 4 @ 4-Ohms
250 Watts x 4 @ 2-Ohms
500 Watts x 2 @ 4-Ohms Bridged
STABLE @ 2-Ohms x 2 Bridged (reduced thermal time may occur)
Total Power
(Sum of Rated Power) 1000 Watts
Dynamic Power
(PVC/PowerCube® Measurement) Front Channels:
222 Watts x 2 @ 4-Ohms 0° Res
390 Watts x 2 @ 2-Ohms 0° Res
Rear Channels:
223 Watts x 2 @ 4-Ohms 0° Res
387 Watts x 2 @ 2-Ohms 0° Res
Bridgeable Yes
Efficiency (average) 70% @ 4-Ohm
65% @ 2-Ohm
Crossover Controls Front Channels: High-Pass (HP): 50Hz-500Hz @ 24dB/octave Butterworth
Low-Pass (LP): 50Hz-500Hz @ 24dB/octave Butterworth
Rear Channels:
Tone Controls Front Channels:
Treble: 0dB to +12dB @ 12kHz
Bass: 0dB to +18dB @ 45Hz
Rear Channels:
Function depends upon crossover setting (LP/AP/HP)
Signal Input Front Channels:
1 RCA pair
Rear Channels:
1 RCA pair
Signal Output 1 RCA pair
Power Input Connector Block
Power Wire Gauge 1/0 AWG
Speaker Output Connector Block
Speaker Wire Gauge 8 AWG to 16 AWG
Heat Sink Type Cast aluminum
Cooling Convection
Remote Controls Optional Remote PEQ
(overrides rear channel built-in Punch EQ)
Visual Indicators Power (Blue LED)
Thermal (Red LED)
Protect (Yellow LED)
Front Output -00dB to +2dB @ 11 steps (Blue LEDs)
Rear Output -00dB to +2dB @ 11 steps (Blue LEDs)
Circuit Topology Class Class A/B
Frequency Response 20Hz to 20kHz +/-1dB
Shipping Weight 19.6 Lbs.
(8.89 Kg.)
Dimensions (HxWxL) 2.14 x 8.14 x 21.875 (in)
5.44 x 20.68 x 55.66 (cm)
Dimensional Diagram
Edited by siccostyle
01 2dr ExploderBuild log2 18" DC Level 6's (M3's)DC 10k5 XS d3100's, DC 390 alt100' shok ofc cable
Team ShokTEAM SUB SONIC ADDICTION
if you expect trades let me know bro i got tons of stuff, pm me
Not really looking to trade unless it's for cash or a alt.
This topic is now closed to further replies.
