SMD/AA 15 T-Line HUGE BOX 16.7 cuft
I had fun with this, was just curious how large it would be and it is quite big, I've been told T-Lines arent good with high amounts of power, but as I said this was just for fun, 1 SMD woofer cost moe than my entire setup, so no way would this come to fruition at least not by me
This box has a lot of port, mainly due to its nearly 16 inches of mounting depth
SUB: SMD / AA 15
Dual 2
Fs: 30.1
Qms: 4.99
Qes: 0.29
Qts: 0.27
Sd: 810cm^2 (half of actual port area, lol)
Mounting Depth: 15.75 including stud
Outer Diameter: 15.625
Cutout Diameter: 14.125
Sub Displacement: .24 cuft
Weight: 73 pounds
Box:
Outer Dimension: 63 wide x 39 deep x 20 tall
Inner Volume: 16.65 cuft after displacement (not accounting further bracing)
Tuned to 29.7 Hz
Port Length: 114 inches
Port area: 256 inches (yes tons, not sure how that will affect its functioning within the T-Line)
Now I think if this worked, 3 of these next to each other or stacked in a walled type of configuration (floor to ceiling) would just be cool, just cause I like T-Lines, for the money spent and functionality you would probably want, much easier way to go about a setup like this of course, I just wanted to see how it would look
Inside View
Complete with X ray
Complete
Since it will be a while before I can afford my sub, and I have my own design for a box done and too much free time due to no job, I just have a bit of fun trying to design boxes, I wish I knew more about 4th, 6th, and BP designs, those would be fun
Edited by kynto
You could do a classical t-line where you start out at 1.5-2x the sd of the sub and taper it down to 1x the sd. I've never seen anyone do 2x the sd all the way through the line.
Ryan Miskin - owner of RAM Designs
I have my PM's turned off, please email at <script data-cfhash='f9e31' type="text/javascript"> /* */</script>
2200+ designs since March 2011...
Yea, I could taper it, didnt think of that
I wouldnt mind trying a taper, I dont know how that affects tuning though and how to calculate for that, is it sort of like horn theory, cause I dont know how to calculate that either
  • Who's Online   0 Members, 0 Anonymous, 1767 Guests (See full list)
