Can I get some help from someone who passed geometry...?
sqsux
I've got this trapezoid shaped box and i can't figure the volume of it out.
i've found formula's online, but they either calculate it for you and don't tell you the unit of measurement or i just don't know how to convert it to cubic feet.
measurements for those who can't read the picture
w1 = 38.25
w2=43.75
height = 4
depth = 28.5
Start out boxy, shape as you move along.
Dc Audio
Team Fur
I came up with 2.7 ft^3 before all displacements
Just a ballpark, but should be pretty damn close
Edit-Explanation, correct me if I'm wrong.
(w1 + w2) divided by 2 =41 inches
41*4*28.5=4674 in^3
4674/1728=2.70xxxxx ft^3
4" high? Or do you mean 4 feet (48") high? I only ask because 4" is a REALLY small dimension for a box, ain't it?
If it's the latter, you are about 32.5 cubes gross.
If it really is 4", then yes, about 2.7 cubes.
41*4*28.5=4674 in^3
pretty close to my original estimate, 2 cubes smaller.
Dc Audio
Team Fur
w1 = 38.25
w2=43.75
height = 4
depth = 28.5
are you figuring off of these numbers, or do you need it to be calculated with a displacement for a thickness of material?
Owner of BigAss Ports
those measurements are in inches i suppose?
take the thing apart you have a rectangular prism and two triangular prisms which make up another rectangular prism
volume is 4674 in^3 or 2.71 ft^3
edit. whoa... slow typer on mobile :/
An Audio Technix 18" Strato on a Kicker KX120.2
My Youtube Bass Vids
Updates When Possible...
I've bought from JBurt09, OrionStang, bcpballer64, LoudNLow931, audioman21, and CJ18 from here (as refs)
Also, to figure volume of a trapezoid, this is the formula, if measuring the box in inches:
[(w1+w2) x height x depth] then divide by 2. My head hurts from trying to write out the equation lol.
1728
inches, this is actually the top of my wall not an actual box. i orginally estimated 22 cubes gross and from what you guys tell me it's actually 20ish.
but yes 4 inches not feet.
Dc Audio
Team Fur
Volume = Length * (Base 1 + (Base 2 - Base 1) * Height + Base 1) * Height / 2
Or, an online converter...
Online Conversion - Volume of a Trapezoid tank http://bit.ly/iXpicY
Chris - "The Apprentice" - Pandora's Box Customs
1994 Ford Explorer - "Midnight" - 4.0L SOHC
SoundStream PCX-1000D & Kicker S12L5
  • Who's Online   0 Members, 0 Anonymous, 5764 Guests (See full list)
