Nothing wrong with the CompVR man. Run what you want to run.
Like they said yep you can wire 8 d4s into a 1 ohm load. series them all to be 8 ohm then parallel them all to a 1 ohm load.
Just to allow a more even flow of electricity I would make two sets of four 8 ohm woofers to get each set of four to 2 ohms then I would parallel your 2 sets of 2 ohm loads together to get 1 ohm.
If I confused you do it the easiest way possible.
Edited by ISO
Isobaric - Refers to the practice of coupling two drivers together to make them act as one.
"Giving up doesn't always mean you are weak; sometimes it means that you are strong enough to let go."
Insanity: doing the same thing over and over again and expecting different results.
The Destruction of a person builds character.
