Hey guys, I am currently building a sub enclosure (my first) and I am just about to sand the pieces and seal up the box. Before I do that I would like to get some input on the tuning frequency that I have chosen for my box because I would rather not have to tear it apart later because it sounds bad. The link below is to the Thiele-Small data sheet for my woofer (p3d210). The box I designed will have an interior volume of 1.4 cu. ft. and as of right now it will be tuned to 40.5 Hz (both are manufacturer recommended), I do not know enough about the data sheet numbers to determine if the woofer will perform better with a higher or lower tuning frequency, I listen to every kind of music there is so the box would need to be "multi-purpose". Any input would be greatly appreciated, I am very excited to get this box finished up and see all my work pay off :)
http://www.rockfordfosgate.com/rftech/library/2007/5_Subwoofers/P3D210_revA-TS.pdf
you could have done the rectangular version and made different sizes as well
Part of my problem is with my current design 1 of the walls of the port is shared with the box, so if I were to try to make that interchangeable the port wouldn't really be sealed right imo, if i were to move the port over far enough to eliminate that problem then I am looking at a gaping hole in the baffle ><
I forgot to mention that I will be running the sub off of a sony xplod amp pushing 500RMS, from what I have been reading putting that extra 100rms should be ok for the woofer as long as I don't clip it. If that is incorrect please let me know.
You probably aren't seeing anywhere near 500 rms after all is said and done. What model is it.
--2004 Toyota 4runner
New Build Log
-2002 Acura Tl-S
Old Build Log
Team DC Audio
spl dust is an option you can get on the coils... it's great for extra 1000 watts of power
where can i get this spl dust and how much is it. is it hard to apply? lol
  • Who's Online   0 Members, 0 Anonymous, 612 Guests (See full list)
