my 2001 Toyta Avalon XLS build up (new build w/pics) 2/25/13
ok well the rebuild has started finally!!!! Got the new wiring and deadener installed and the XS Power D925 in. I have run out of time for today but i'll have pics up tomorrow of the progress so far. Tomorrow i have to get the amp mounted and installed and then get the Re Audio SE-X 12's in to the box which i had to already modify to get them in there. I'll have pics up tomorrow like i said.
Might even have to do me a UBL just for this build. I hope ya'll like it and if ya don't then GFY. That is all....
2001 Toyota Avalon (stock other than system)2009 Mitsubishi Lancer GTS (Cat-back custom Exhaust w/ Magnaflow muffler, ECU Flash)1966 Chevelle SS (402BBC, Built TH350 w/2500 stall, Flowmaster exhaust, Coy 5 Spoke Rims, Holley Carb, Elderbrock Intake, Comp Cams Valve Train)Current in Avalon:Kenwood DNX5180 HUJBL 6.5" in front doorsJBL 3/4" tweets in dashJBL 3.5" rear doorsJBL 200w 4ch amp
RE Audio SEX 12D4 Subs (12")
Hifonics Brutus BRZ1200.1D
NVX 4 gauge wiring
NVX Deadner
XS Power D925
Big 3 1/0 ga Q Power wire
Custom box by Pro Audio Gulfport, MS
137.5 SB2 USACIhttp://www.stevemead...on-xls-build-up
ok well its finished finally. got it playing and just waiting on my friend to use his DD-1 to help me setup the gain on the amp. In the mean time here are some pics for y'all to take a look at.
NVX 4 gauge wiring
NVX Deadner
XS Power D925
So from what i'm hearing i'm more than likely still going to have to break down and build a new box for these subs. the box they are in is dual chambered so that each sub is alone and doesn't affect the other. with the back seat out of the car it gets very loud and moves good air but with the seat back in (seat doesn't fold down..yet!!!) it gets low but not loud. Anyone have any idea's what is going on. subs are facing rear of car as are the ports and box is 36x16.5x16.5 with ports being 15x1.5wX14.25D on one side of port being that it is using one of the outside walls of the box for outside wall of the port. I have no real idea on the specs on this box other than it was built for my Memphis PR 12's that were in it.
NVX 4 gauge wiring
NVX Deadner
XS Power D925
NVX 4 gauge wiring
NVX Deadner
XS Power D925
The box looks choked as hell with the ports the way they are. Definitely build a box for those REs and you won't be disappointed that you chose to. I'd do a common chambered box with a center port, or a port to one side even. Get that area per foot up, and port width as well. A lot of gain and enjoyment can be had with a new box for you :)
I only have one problem with that. I have no idea where to start with a box design for these subs. I know what the specs are from RE but i have never built a box on my own per say. I have helped cut and glue them together. the width of the has to say as it is at 36" b/c thats as wide as i can get in the car but as for the height i would really like to drop it down to say 15" to get it under the back shelf in the car behind the back seat. as far as depth goes, i could go as much as 24-26" and still not be on top of the amp. if you know of any idea's i would appreciate the help. I know i would like to get it into the low 30's hz range but as before i have no idea where to start, lol. HELP!!!!
NVX 4 gauge wiring
NVX Deadner
XS Power D925
ok who do i need to talk to about getting a design done for my box? i have all the measurements that i think i would need to give them.
NVX 4 gauge wiring
NVX Deadner
XS Power D925
