Jmoney2544 Posted June 16, 2011 Report Posted June 16, 2011 I Got This 5.25" Component System With These passive Crossovers... I wanted to instal these on my amp rack which is located Behind my back seats. This 5.25" set is for the front doors and was wondering if i installed the crossovers on the amp rack in the back and ran like 15 ft of speaker wire from the front to the back, and then back again would there be a delay in the sound, or is that fine? I don't know if 30 ft of speaker wire will produce a delay, or if its generally not a good idea. What are your thoughts on this? Any Other idea's? Car: 2002 Buick Regal Wiring: Knu Kolossus 1/0 + JL 4 Gauge Big 3: Stinger HPM 1/0 Alternator: Stock 135 Amp Batterys: Optima RedTop (Hood) XS D3100 (Trunk) HeadUnit: Pioneer DEH-4200UB Subs: (2) AQ HDC3 12's Sub Amp: AQ 2200D Sub Box: 4.6 Cubes @ 36hz Mids & Highs: (Front) Rockford Fosgate Power T1693 3-Way 6x9's Mids & Highs: (Rear ) Rockford Fosgate Power T152S 2-Way Component 5.25" Speaker Amp: AQ4x90 Sound Dampener : 75 Ft Fatmat
bumonskateboard6 Posted June 16, 2011 Report Posted June 16, 2011 I usually mount crossovers on the doors to limit the distance from the crossover to the speaker, it's also a PAIN in the ass to run more than 1 speaker wire through the boot in the door. If I am mounting tweeters in the A pillar I put the crossover under the dash. Current Systems: 2011 BMW 335i Hertz HDP1 DC LVL3 12" Full Carbon Fiber 2002 Acura TlKenwood DNX9980HD2 DCLVL4 12" Subs with LVL5 Parts D.7 CoilsDC 3.5kHertz HSK-165 up front HCX-165 RearHertz HDP4 AmpDC Power Engineering 260 Amp AltBig 3 and amp powered with KNU 1/0XS Power D2400 Up Front i pulled out my dick in class many of times and had it shown. get over it bitch...stupid open legged hairy beavered bitch... going over rms = smaller box, under rms = bigger box... Low voltage doesn't blow amps. That's a myth. A router that does the sub holes makes rounded edges also?
Jmoney2544 Posted June 16, 2011 Author Report Posted June 16, 2011 I usually mount crossovers on the doors to limit the distance from the crossover to the speaker, it's also a PAIN in the ass to run more than 1 speaker wire through the boot in the door. If I am mounting tweeters in the A pillar I put the crossover under the dash. How do they handle with water? because if i mount them to my doors and its pouting out... there obviously gonna get rained on. Car: 2002 Buick Regal Wiring: Knu Kolossus 1/0 + JL 4 Gauge Big 3: Stinger HPM 1/0 Alternator: Stock 135 Amp Batterys: Optima RedTop (Hood) XS D3100 (Trunk) HeadUnit: Pioneer DEH-4200UB Subs: (2) AQ HDC3 12's Sub Amp: AQ 2200D Sub Box: 4.6 Cubes @ 36hz Mids & Highs: (Front) Rockford Fosgate Power T1693 3-Way 6x9's Mids & Highs: (Rear ) Rockford Fosgate Power T152S 2-Way Component 5.25" Speaker Amp: AQ4x90 Sound Dampener : 75 Ft Fatmat
PUNKYOU007 Posted June 16, 2011 Report Posted June 16, 2011 I usually mount crossovers on the doors to limit the distance from the crossover to the speaker, it's also a PAIN in the ass to run more than 1 speaker wire through the boot in the door. If I am mounting tweeters in the A pillar I put the crossover under the dash. x2 Although I have never had any issues running crossovers for the front doors in the trunk. Just as stated, you will have to run twice the amount of wire and it can be a bitch getting it through those rubber door boots. As for the water issue, try to mount them between the door skin and the door panel. Not always enough room tho. You could also take some plastic and cover them if you mount them between the door skins. Doethepaperboy "Bars of Pain" Doethepaperboy "Hero Remix" C. Arson d(-__-)b beer sucks...but i can bring some jose cuervo. Only problem is that it makes me horny and gives me the rams. So unless yall wanna fight and then have some great make up sex i will leave it home.
