anyone think i could run my Hifonics BRZ 2400.1 at 2 ohms on my 2 kicker cvr 12's? lol it says 1700Rms@ 2ohms.. and i hear the kickers are tought haha this new amp is driving me crazy just sitting here, and i can't find 2 more kickers anywhere right now
Driving my 2008 Dodge Ram 2500 MEGA cab with the 5.7 hemi.
Audio: Two 10" Alpine Type R's ( 1000rms models )
Hifonics BRZ 2400.1D @ .5 ohm
Two Kinetic 1400 batteries ( soon to have XS power under hood )
Tsunami 1/0 Awg wire throughout truck.
Stock Infinity 7 speaker system ( Junk ) soon to be replaced, probably all Alpine.
Exterior: 17"Dick cepek rims with 33" Toyo MT tires
Bushwacker fender flares
Magnaflow true duel exhaust
LED tail lights with Projector headlights
Plasti-dip fun coming soon!
Well seeing how you have to split them between the two, you'll be getting 850 each, if your going to push them that hard, i personally think that's way to much for these subs, there 400rms each, you could push them a little harder than that but i wouldn't expect double what it says. On the bright side, you'll be able to push those subs without over working your amp :)
Edited by TheNewbie
Check out my build log:
http://www.stevemead...60#entry1958353
Different folks have different strokes.
If you do it right and know your stuff, then maybe
I have a friend that ran a hifonics 2600 (brutus i think, think it was 2600) on 2 15 inch cvr's, they sounded nice, did a 145.4 on TL
however im sure they are rated at 500rms each, so youd have to be sure the enclosure, wiring, etc. is all good
shoudlnt overpower subs unless you know what your doing
BTW, i believe amp was clamped at giving an actual like 1550 or 1650 rms, so 700-800 rms per woofer
however not suggesting to overpower, just saying its been done by someone who knew what they were doing
Edited by kynto
i had my alpine 10" type R on 1000rms before..but i think i might just hook my hifonics to the kickers with gain REALL low, and play from there.. i really just wanna use the bass knob haha
do it but dont use that gain on the amp give a good clean signal an see how long the last!
Vehicle: 2017 Chevrolet Silverado High Country
Electrical: 320A Singer Alt, (2) Limitless Lithium 15ah, Full Throttle FT680-48
Speakers: Stevens Audio SA 6 (ACTIVE), Audio Designs 3”
Subwoofer: (4) B2 Audio XM 8’s
Amplifiers: (2) B2 Audio Rage 2500.1, (1) B2 Audio Rage 1200.6
Processors: NavTv M650 (integration), Helix DSP Pro MK2
Silverado Build Log
The bass knob will only go as high as you set your gains on youramp :) so if you set your gains so that your pumping 400 to each, you can crank that bass knob all the way and it will only push out 400 to each :D and once you go lower on the bass knob of course lower the wattage to each.
dont use teh gain on the amp? then what gain am i supposed to use lol
well screw it , im gonna go hook it up right now, i got the kickers really cheap anyway, and i have 3 other subs ( RE SX 15s and a type R ) in my room incase they blow haha
  • Who's Online   0 Members, 0 Anonymous, 779 Guests (See full list)
